soild crush sleeve?
Old Mar 20, 2009 | 01:43 PM
ryan91rs's Avatar
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
soild crush sleeve?
anyone know where i can buy a solid crush sleeve aka crush sleeve eliminator? Can't find one anywhere! post a link if you have it please.
Old Mar 20, 2009 | 02:31 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: soild crush sleeve?
Ratech
http://www.ratechmfg.com/toc.htm
Hint- it's just a sleeve. I paid $20 for mine, plus $40 in shipping and duty and was ANGRY. Just remove your existing crush sleeve, measure it's ID, OD, and length, and buy some tubing and cut to length. Cut it long, grind it to size, and try it out. Leave it .003" long or so. Check the bearing preload, if not enough, grind it shorter, etc etc. Beats waiting a week to ship a $20 part that is worth $3.
Old Mar 20, 2009 | 02:57 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
This is where I purchased mine, for less than $20 a couple of years ago. http://www.ringpinion.com/
Give them a call, they'll help and get you set up.
Old Mar 20, 2009 | 02:58 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Well hot dang! Thanks. I was wondering about that sleeve.
Old Mar 20, 2009 | 05:43 PM
big gear head's Avatar
It needs to be cut in a lathe. The ends must be parrallel or the bearings can be cocked slightly and cause uneven wear. It must seat evenly on the bearings. It is best to get one that is short and shim it to the correct thickness.
Old Mar 20, 2009 | 05:51 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Surely my local general-machine shop will do it quicker and for less than the $60 sonix told us about. Thanks big gear head.
Old Mar 22, 2009 | 10:38 PM
ryan91rs's Avatar
Transmission: 4L60
why machine them? never heard of that. Thanks people! been looking! All the manuals and pros never told me about machining them.
Old Mar 22, 2009 | 11:06 PM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
does this help and is it what you are looking for?
http://cgi.ebay.com/ebaymotors/ws/eB...11025&viewitem=
yes i know its ebay but i look there all the time and just hit save on some things so i can find them later.
Old Mar 27, 2009 | 01:46 PM
ryan91rs's Avatar
Transmission: 4L60
thats a sleeve for a cylinder not for a pinion crush sleeve alternative
Old Mar 27, 2009 | 11:41 PM
Why do you want a solid spacer for the 7.5 rear end? The crush spacer is plenty good. The 7.5 will break many more parts before the spacer gives any problems.
GTAman
Jul 3, 2024 07:29 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
loud91rs
Oct 5, 2015 10:05 PM
gord327
Sep 29, 2015 10:18 PM
