What thread size are the T5 shifters?
Old Jun 25, 2001 | 03:35 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I want to order a billet shift **** from Mallory but I don't know what size thread it is. Anybody know off hand or do I have to whip out the old assorted nut drawer?
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Jun 26, 2001 | 12:29 AM
Tom Keliher's Avatar
9/16" diameter.
Old Jun 26, 2001 | 06:56 AM
Jim85IROC's Avatar
Thanks Tom. You wouldn't happen to know the thread size, or at least if it's the same as 4th gens would you? I would assume the 4th gen T5s would have the same thread size, but with GM you never know.
I drilled and tapped an 8 ball years ago for my firebird, and it currently resides in my Sport Coupe, but I can't get the **** off any more to look at the threads. It's on there so tight I'm afraid that I'll ruin the threads trying to get it off.
The IROC Homepage
Old Jun 26, 2001 | 08:55 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
They're 14mm "standard" thread, whatever that pitch is. I think it's 1.5.
I took a bolt that size, drilled it out and tapped it to 3/8" fine, cut off about ½" of it, and Loctited it to my Hurst Comp Plus T-5 shifter because I hated the Hurst **** so bad... the stock leather one looks so much better than that cheesy thing Hurst supplies.
ICON Motorsports
Old Jun 27, 2001 | 12:07 AM
MRZ28HO's Avatar
Car: was: 1984 Camaro Z28
Engine: was: L69
Transmission: was: 700-R4
Actually, it is the same for both M16x1.50. I just check with both my shifters.
George P. Lara
1984 Z28
SCCA, SCFB, SC3GFB
Old Jun 27, 2001 | 07:06 AM
Jim85IROC's Avatar
Thanks.
The IROC Homepage
Old Jun 29, 2001 | 03:27 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
When I put a Hurst T-Handle on my Hurst Shifter, it was 7/16"-20. The stock **** fit so its the same?
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Jun 29, 2001 | 08:03 AM
MRZ28HO's Avatar
Engine: was: L69
Kev, some aftermarket shifters use dual thread patterns ( whoops), vary depending on manufacturer. But as you know, I have the OEM manual stuff from a '91 Z28 (Christina's car), well I took off the shift ****. Went over to my 1994 and swapped *****, no problem. I also have various taps, dies and thread "finders", matched up the pitch and measured the diameter = M16x1.50 for both.
EDIT: That's better.
[This message has been edited by MRZ28HO (edited July 02, 2001).]
Old Mar 14, 2005 | 02:22 PM
peteman70's Avatar
Car: 1987 Camaro
Engine: 305 CI of SBC Goodness
Transmission: 5 speed Manual
I know I'm bringing up a really really old topic here, but I'm a bit confused...is the diameter 14 mm or 16 mm? Thank you.
PurelyPMD
May 5, 2016 04:57 PM
Drone358
Sep 28, 2015 04:55 PM
armybyrd
Sep 16, 2015 07:00 AM
89formula#1
May 8, 2002 12:15 PM
86IROC
Feb 17, 2001 03:59 AM
