Pilot Bearing Installation
Old Jun 29, 2001 | 04:18 PM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
How far is it supposed to drive into the crankshaft??? Mine seems to only drive in half way, or is that normal?? I don't have a picture in my shop manual...it just says to drive it in with a tool. My old one fell out when I pulled the trans, so I have no idea how far it should go into the bore. Any help would be appreciated. - Jeff
BTW...I don't want to discover it's not in far enough after I have the tranny balanced on my chest under the car!!
-1983 L69 Camaro Z28 305 H.O. (Bored .030 over,Teflon oil seals,Melling oil pump,Hyperetic pistons,chrome-moly rings,2040 Crane compu-cam) T-tops, 3:73 Open rear, BW T-5, Rebuilt E4ME 4 Barrel, Duel Snorkle, Rhino Clutch, 2040 Compu-cam, LS1 valve springs, porting, PST front end kit with new springs, K&N Filter and runs great but ain't streetable yet!!....Future Mods: JUNK IT if this keeps up!!
Old Jun 29, 2001 | 08:24 PM
Jay 727's Avatar
It should go flush with the crank, I've seen a pilot bushing fall out on a friends firebird, a small piece was still stuck in the crank, maybe you have a part of the old one still in your and need to remove it.
Old Jun 29, 2001 | 10:54 PM
Confuzed1's Avatar
Car: 83Z28 HO
Thanks for the info Jay - I was afraid of that!! I could only drive the bearing in half-way, probably got jammed in crooked somehow. What's the best way to get it out when it jams up??
Old Jun 30, 2001 | 01:01 PM
84TransAm's Avatar
Why the nasty grease trick of course!! Pilot bearings are a big PITA if you don't have a pilot bearing puller. They aren't cheap or easy to come by either. If you have a friend who has one, try to borrow it.
--Steve S--
1984 Trans Am 305 LG4, 5 speed Daily Driver, Flowmaster 80 Series
Holley 600 cfm & vacuum advance
Soon: Edlebrock Intake & TES
anesthes
Mar 10, 2016 10:35 PM
red90IROCls1
Aug 25, 2015 06:56 AM
gwade12
Aug 8, 2015 08:17 AM
rsrmoore
Aug 7, 2015 08:44 PM
