torque converter lock up switch??
Old Jun 30, 2001 | 05:58 PM
Camarokid01's Avatar
I need a manual lock up switch for my torque converter, does anyone know where they sell them, I found one in jegs but I don't really like it.
Thanks everyone
Old Jun 30, 2001 | 07:20 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Which one did you find and why didn't you like it?
Old Jun 30, 2001 | 08:22 PM
82camaro's Avatar
Car: 82 camaro SC
What he said above, and how much control do you want?
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, current red metallic paint. Lots of other stuff...
82camaro
Old Jun 30, 2001 | 11:03 PM
the one I saw was the one where you just turn a dial to the MPH you want it to lock up at. but I saw one in the camaro performance magazine that some guy had and it was just a switch you can turn off or on. The reason I don't like the dial one is because if I am out on the street I don't want to have to turn the **** so that the lockup won't come on if I am racing. I just want to be able to switch it on or off as I please and not just set it on a dial.
Hope you get what I am saying, I don't really know how to explain it.
Thanks everyone
Old Jun 30, 2001 | 11:32 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Ok, the one you're thinking of is the B&M kit, which has a part that goes inline with the speedo cable to lock up above a certain speed. I believe it also has a vacuum switch that unlocks the TCC under load, but I'm not sure.
It sounds like you just want a manual switch, in which case you can just use any old toggle switch.
Old Jul 1, 2001 | 07:40 PM
junkyarddog's Avatar
Car: 1999 Chevy Cavalier
Engine: 2.2
Transmission: 5 speed
Axle/Gears: it's part of the transmission
short the top left and the top right pins on the ALDL connector together using a switch,mount the switch right on your shifter if you can,full lock up in 2nd is great!
Old Jul 1, 2001 | 11:22 PM
breathment's Avatar
Wut exactly does locking ur converter do, im also thinking about installing one, but i want more info on how it helps,
1992 Trans Am
May 10, 2023 07:19 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
jklein337
Sep 19, 2018 06:23 PM
xxx3man`
Sep 23, 2015 10:37 PM
gwade12
Aug 8, 2015 08:17 AM
