started doin my T56 swap, have questions...
Old Mar 28, 2009 | 05:44 PM
86camaro383's Avatar
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
Well i started doing my t56 swap and have a couple of questions. Well, 1 question right now. I pulled put the brake booster, and right below it, theres a hole stamped out already. This is a 1986 iroc, that was automatic. Is this the location of were the stock master cylinder would be? If it is, Im using 4th gen pedals and master cylinder, so do I just use that hole?
Old Mar 28, 2009 | 07:43 PM
likeenz24's Avatar
Car: 87 Camaro
Engine: 406
Axle/Gears: 9" ford 35 spline axles
Re: started doin my T56 swap, have questions...
one way to double check it would be to bolt the pedals in and then drill the clu master cylinder holes where the pedal braces meet the firewall. Good call on the 4th gen pedals. I had trouble at first when I was using 3rd gen ones.
Old Apr 8, 2009 | 06:37 PM
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
alright I got that all done. Wasnt that bad. For anyone that does this, I found by dropping the steering column ( 2 15MM bolts) made it extremly easy to get to the top 2 brake booster bolts. On to the pilot bearing....does that installed so it bottoms out in the crankshaft, or does it get installed to its flush with it.
Old Apr 8, 2009 | 08:39 PM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Should be flush with the stepped lip of the crank. If you have a bearing, it should have the small seal towards the outside of the crank.
Old Apr 8, 2009 | 08:53 PM
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
alright cool....thats How I had it. I put the clutch togather, slapped the bellhousing on. When i went to bolt the tranny to the bellhousing, there was about a 1/8 gap, I couldnt get it to line up. I ended using the 8 bolts that connect the 2 to draw it in. Im just wondering if i didnt have the clutch disc lined up perfect.
Old Apr 8, 2009 | 08:55 PM
85MikeTPI's Avatar
If you only had 1/8" gap, then you were already past the clutch splines, probably just friction on the dowels.
Old Apr 9, 2009 | 06:47 AM
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
fair enough...tonight im going to work on getting the wiring all set. thanks again.
Old Apr 12, 2009 | 01:10 PM
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
alright, I have a stock 700r4 driveshaft from a thirdgen...It doesnt want to go into the tranny, I was under the impression that it would work?
Old Apr 12, 2009 | 04:20 PM
85MikeTPI's Avatar
exactly the same output shaft. If it doesn't fit, then someone may have changed the yoke on the driveshaft, the DS is actually not from a 700r4/T5 thirdgen, you have a viper-spec T56, or the splines are twisted on either the yoke or T56 outputshaft..
Old Apr 12, 2009 | 05:29 PM
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
possibley, I have to check some stuff out. I know the t56 is from a 94 camaro, the cuy I bought it off of is the orignal owner, I know the driveshaft is from a thirdgen 700r4, i have another d/s, ill give that a try, thanks again man.
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
jharrison5
Aug 19, 2015 05:53 PM
sreZ28
Aug 14, 2015 07:48 PM
hokis
Aug 9, 2015 03:57 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
