problem shifting t-5
i am having a problem down shifting from 5th to 4th it wont do it. is my tranny toast how much to fix? goes up through the gears ok but 4th is still a little sticky even going up.
help needed.
dave
help needed.
dave
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
hmmmmm
my camaro was like that, but it was sticky in 3rd
one day it just stuck and never came out
rebuild cost $1600
they told me my synchro's went bad
rebuild cost $1600
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
It sounds like your shifting fork's plastic pices or your sincros are going south. you can either have it rebuilt wich will cost you an arm and a leg or you can try to do it yourself. It's pretty straight forard if you have a manual (mine's back in N.J I'll have to get it next time I go on leave) just make sure you dont loose any keepers- GM no longer sells them by themselfs I nedded to go to ford(sorry I was out of options) By the way the mustang and jeep T5 is the same intarnilly as ours the only diffrance is the case and input/ouput shafts so any parts that are discotinusd by GM you can get from ford or chrisler and one more thing if you change any gears(chipt teeth, ect)get the proper # of teeth or the tranny wont work.
someone972
Aug 30, 2015 12:52 AM
dhonda200
Aug 11, 2015 11:50 PM
