2nd Accumluator spring broken!!! need help>>
Old Jul 6, 2001 | 01:24 AM
Hecubus's Avatar
Car: 91 z82
Engine: 5.0
Transmission: pro-built 700r4: 2400 stall
check this out > http://www.geocities.com/hecubus91/2nd_acum.htm
I was installing my shift kit and found it like that
what could have been the cause of this??
and what might the symptoms have been that it might have created????
Prob. a Dealer part I'm shure..... damn!
what do you guys think???
thanks
Hecubus
Check out my new site http://www.geocities.com/hecubus91
91-Z28 305 Tpi "G92" mods-- K$N/Foil/Cat Back 3" Flowmaster/3" High Flow Cat/B&M shifter/ Intrax Springs/ Kyb Shock's-Struts's/Poly Bushings/Hotchkis Strut Tower Brace/Nos Wet Plate System currently ~200hp shot/ 155lph Fuel Pump/ Holly Adj. Fuel Press. Regulator/Digital Fuel,Air-fuel, voltage & Oil Press Guage's/MSD 6al/ Blaster coil/ Optima,Yellow top batt.
"I spent all my money on race cars, beer, and Broads... The Rest I wasted"
Old Jul 6, 2001 | 02:44 AM
transfixleo's Avatar
It happens all the time. It will tend to make the 1-2 shift bumpy at different throttle positions.
Old Jul 6, 2001 | 03:01 AM
Hecubus's Avatar
Car: 91 z82
Engine: 5.0
ok thanks
and I just took another look at the kit and it come's with new one's
I thought they were for the servo or something I was wrong
one last thing
using the full-auto kit would I have to make all thoes mod.s to the seperator plate??? or is that for stick
thanks again
Hecubus
Old Jul 6, 2001 | 07:17 AM
Pro Built Automatics's Avatar
You have to follow the instructions closely. Yes, there a lot of modifications to the valve body plate. If you goof here it can be big time problems, "follow the instructions closely".
This Should Help!!!
Old Jul 6, 2001 | 04:07 PM
IF you are talking about the TransGo Reprogramming Kit do this. BEFORE you start working on the car again, sit down at the kitchen table with a cup of coffee and a highlighting pen. Go over the sections that apply to you (some you will have to check the VB on to know what to do) so that you don't get mixed up on something. This way you will be able to cruise right through it.
Old Jul 6, 2001 | 09:16 PM
Jza's Avatar
Jza
I've rebuilt a couple 700s that had the same spring broken, in the same coil, with the same shaped break.
They're only a couple bucks if one's not in your kit. Should be a purple spring.
87v6Bird
Jul 1, 2018 04:12 PM
skeltor
Feb 2, 2016 10:37 AM
sandman92084
Sep 12, 2015 10:27 PM
lakeffect2
Sep 7, 2015 03:52 PM
