need a quick answer to a simple question (trans removal)
Old Jul 9, 2001 | 01:41 AM
CrazyRob75's Avatar
i need to change my flexplate. i'm doing it at home. Because of the torque arm, do i also need to jack the rear of the car up as well as the front? or can i just lift the front and that will be good enough? I just plan on sliding the tranny back far enough in the trans tunnel to get to the flywheel2Crank bolts....tia
85 Berlinetta Iroc exterior NOW 454 powered, 4.10 gears, 275/60/15 Hoosier Quicktimes and a PILE of other goodies..........YES, it's street driven!
check it out at http://www.bsronline.net/members/rob/rob_specs.html
Old Jul 9, 2001 | 03:02 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It'd probably be easier to jack the rear up to the same height as the front, or else when you try to reinstall the trans you'll have to worry about tilting it and moving it up and forward to mate with the dowel pins. Assuming, of course, that you can even squeeze under there with the rear still on the ground.
Jorlain
Aug 24, 2022 05:11 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
camaroken83
Aug 10, 2015 11:35 AM
3rdgenparts
Aug 8, 2015 07:09 PM
