pilot bearing question
Car: 1991 Trans Am GTA
Engine: 502 Ram Jet
Transmission: TKO600-racing gears
Axle/Gears: 12 Bolt Moser-33"axles-3.91 ratio
What happens if you put the pilot bearing otherway around? I checked that I should slide it with the lip looking to the transmission side, but I did it as the lip looks to engine side... It work fine though... except my pedal stays a little bit higher than the brake pedal (1.5 cm) I guess it has noting to do with the pilot bearing but I am curious about the consequences... shorty, Is it OK to put the pilot bearing with the lip stays towards the engine?
Thank you..
Thank you..
red90IROCls1
Aug 25, 2015 06:56 AM
rsrmoore
Aug 7, 2015 08:44 PM
