Trans Mount Question
Old Jul 10, 2001 | 01:43 AM
JoshDT91's Avatar
Car: 1988 Camaro Sport Coupe
Engine: 2.8L V6
I have a 700-R4 trans and I was wondering if you remove the brace under the transmission do I need anything under it to hold it up like a jack or jackstand? Also this may sound dumb but what in the world is your t.v. cable? I've been reading tons of people talking about it and I'd like to know what it is. Thanks.
2.8L V6 173ci
K&N Air Filters
JET Underdrive Pulleys
Old Jul 10, 2001 | 07:04 AM
purpleworm's Avatar
You definitely have to put something under the tranny if you are taking out the cross member. That is the only thing that holds the tranny and motor up in the back. Just put a jack under it and zip out the 4 crossmember bolts.
SIDE NOTE: If you are going to let the tranny down at all take the cap off the distributor because as you let it come down it will hit the firewall and break.
Old Jul 10, 2001 | 05:48 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
TV stands for "Throttle Valve", and the cable for it runs from the throttle to the transmission. It does more than the old "kick-down" cable of yesteryear, so its proper adjustment is a little more critical. Basically, it varies the pressure within the transmission with varying throttle position, making the shifts softer or firmer, and earlier or later for less or more throttle opening, respectively.
If you are changing your transmission mount, put a 2x4 under the transmission pan and between the jack to hold it all up while you have the crossmember off. The board keeps the jack from deforming the pan, and keeps the jack far enough forward to be out of your way for the mount change.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam and intake, World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
timonator
Aug 11, 2015 09:56 PM
