auto to t56 3 issues
Old Apr 2, 2009 | 07:34 PM
jayk2k3's Avatar
Car: 85 camaro z28
Transmission: auto to manaul
ok, im trying to finish up my t56 swap. It has just been a nitemare, one problem after another. i've now got these issue
my setup is
t56
3gen pedals
1st. i am worried that the clutch isnt fully disengaging, i dont want it to kill my clutch right away ?
2nd. when i install the master cylinder i drilled the hole a 1/2 inch off, so now the bottom 2 bolt holes for the pedals dont line up right. do you think im risking breaking or cracking the firewall, if i dont support the master cylinder with the pedals support ?
3rd. i am using the thirdgen pedals, i heard there might be a problem with the pedals pushing the clutch too far in?
Old Apr 2, 2009 | 10:40 PM
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
Re: auto to t56 3 issues
If you read the T56 sticky thread you will find out that a high pedal is a common problem when using 3rd gen pedals and 4th gen hydraulics. There is a lot of discussion there about this problem. Read through the thread and you should find your answer to this question there.
Old Apr 3, 2009 | 03:18 PM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
i used 3rd gen pedals and just cut the rod in the slave about 1/4 inch or so and rewelded the rod together
Old Apr 3, 2009 | 05:08 PM
jayk2k3's Avatar
Car: 85 camaro z28
did you do that becuz of the high engagement point or because you were worried the clutch wasnt fully disengaging?
Old Apr 5, 2009 | 09:32 AM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
I used 3rd gen pedals with no problem. The clutch engages near the top of the pedal travel, but it isn't uncomfortable to drive. I also have a SPEC stage III clutch, which I think is thinner than stock and may reduce the pedal height somewhat. All in all I'm really happy with teh swap; best mod I've made to date!
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
87 camaro iroc
Aug 20, 2015 07:47 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
Leggman1
Aug 6, 2015 04:15 AM
