How do I change the speedo drive gear?
Old Jul 15, 2001 | 01:34 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
When I swapped transmissions, I swapped the driven gear but not the drive gear into the new trans. I can't get the driven gear off of the output shaft. I depressed the little locking tab, but I can't move it or the gear. How do I get it off?
I apologize if this is somewhere in the archives. I did a search and didn't come up with the info I need.
Oh yeah, one more stupid question (Can you tell I'm not a tranny guy?). Will having the speedo off by 20% or so have a major impact on the drivability and operation of the trans? Before I pull this new trans back out I want to swap the drive gear and see if it has an effect on drivability, but I'm really not expecting it to.
Anyway, thanks for the help.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Jul 15, 2001 | 04:31 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I used an open-end wrench a littler larger than the diameter of the output shaft and tapped it with a deadblow to slide the gear off slowly.
Old Jul 15, 2001 | 06:24 PM
ede's Avatar
ede
i take them off with a bearing seperator in a press, but i doubt if you have your's apart that far. you can put them on by leaving the rear seal out and driving them on with a long piece of round stock for a punch.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Jul 15, 2001 | 07:23 PM
Jay 727's Avatar
[This message has been edited by Jay 727 (edited July 15, 2001).]
Old Jul 15, 2001 | 09:27 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
The procedure Aperion describes is in here: Speedo gear
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
Old Jul 16, 2001 | 07:15 AM
Jim85IROC's Avatar
Thanks.
The IROC Homepage
jklein337
Sep 19, 2018 06:23 PM
maroe624
Apr 16, 2017 08:29 AM
Wade787b
Sep 29, 2015 01:15 PM
jharrison5
Aug 19, 2015 05:53 PM
beachrodder
Aug 7, 2015 04:27 PM
