Best way to pull out axle bearings?
Car: 2015 Camaro Z/28 & 2013 Super Bee
Engine: LS7 and 392 HEMI
I have a 10 bolt from an 86 Firebird I'm working on and wondered how you guys get the axle bearings out from the end of the axle tubes? We tried putting 2 small pieces of steel on a carrage bolt, sticking one piece inside the bearing and one piece on the outside of the axle tube and turning a nut to pull the bearing out, but the steel bent and the bearing didn't move. Any ideas?
89 IROC 350 TPI, 700R4, 2.77 9-bolt w/ full exhaust, some bolt-ons, and free mods-G-Tech timed 14.8 @ 96 w/ terrible tires...Parts currently being shipped: AFR 190's, SuperRam, LPE 219/219 cam, Vigilante TQ converter, a "beefed up" 3.42 10-bolt, and some Spohn suspension parts
Car: 1992 RS
Transmission: 700R-4 when it works
There is a tool that is made for that (slide hammer)but I just pop the axles out and use a push broom handle. Crude but it works
LOBC-- SS-84
92 RS Heritage package with a 305 3" high-flow cat and pipe with a Dynomax 3" in dual 2 1/2" out.
84 El camino- 383 CID, Performer RPM, GMPP vortec heads, Holley 750 D.P.(0-4779c), Crane Energizer 274,Dual 3" Flowmaster 40 Series Exhaust, Turbo 350 (375b), TCI 2500 stall, Richmond 3.42 gears, PST Poly graphite Suspension bushings, PST steering linkage, PST springs, Monte SS sway bays, Wheels from a Third gen(does that count?
LOBC-- SS-84
) Supreme Member
Car: 82 camaro SC
I use the slide hammer method.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, current red metallic paint. Lots of other stuff...
82camaro
82camaro
Car: yep
Engine: uhuh
Transmission: sure does
I went to the hardware store and bought a couple of pieces of 1 inch conduit (metal pipe) and slid it through the pass. side to beat out the drivers side bearing, and visa versa.
Make sure the pin isn't in the carrier
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
[This message has been edited by Engineboy (edited July 14, 2001).]
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
"He can see air"
Car: 4
Engine: 6
Transmission: 5
I do it the same way engineboy does: my favorite is a 6' piece of ¾" galvanized steel water pipe. Sometimes the simplest way is the best, even if it does seem kind of Stone Age!
ICON Motorsports
ICON Motorsports
Car: 1986 Firebird
Engine: 2.8 V6
I made a slide hammer using a spare piece of threaded rod, piece of water pipe, some washers, and a 10 pound plate from my weightlifting set. That way I didn't have to come near my posi unit at all... one side popped out like a charm, the other side took a while (and bent some washers).
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
ambainb
Apr 25, 2016 09:21 PM
red90IROCls1
Aug 25, 2015 06:56 AM
rsrmoore
Aug 7, 2015 08:44 PM
