stock ring and pinion ?
Old Apr 11, 2009 | 08:34 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
A shop here in Santa Rosa CA called “The Rear End Shop” has recommended a slightly used GM OEM 3.42 ring and pinion set along with a set of new 28 spline axles if needed. ( I already bought a 28 spline Eaton Posi. and LPW support cover from them.) Ive read some posts and am slightly concerned about the ring and pinions strength. (Car details are in my signature) Its a dally driver that I'm going to take to the strip to get some ¼ mi times but that's it. How do the stock ring and pinion sets compare in strength to the after market sets? And do you think the OEM set is OK for what I'm doing? (May put in a 330 hp GMPP create engine at a later date.) Thanks
Old Apr 11, 2009 | 08:53 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: stock ring and pinion ?
unless the gears are dirt cheap or free, i would not buy them used.
The ring and pinion are the weak point of the 7.5" axle. They will break sooner or later if you use sticky tires. But people here have managed to get them into the 10's o believe with no breakage, so long as they baby the car off the line.
Old Apr 12, 2009 | 07:07 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Originally Posted by ronusmcmma
Ive read some posts and am slightly concerned abought the ring and pinions strength.... Its a dally driver that im going to take to the strip to get some ¼ mi times but thats it. How do the stock ring and pinion sets compare in strength to the after market sets? And do you think the OEM set is OK for what im doing? (May put in a 330 hp GMPP create engine at a later date.)
Though it makes no real difference, you'd have a 7.625. The after markets are, of course, stronger--and much more expensive. I'd weigh that cost against a few times down the track. I'm running a 350/330 HO Deluxe with an OE 10-bolt. While I've experienced zero problems, I've also dropped the clutch zero times. I've also retained a non-WC T-5. Conclusion: Wrack and ruin depends on the way you drive.
JamesC
Old Apr 13, 2009 | 08:27 PM
big gear head's Avatar
OEM gears are usually quieter than aftermarket. If they are set up correctly then they will probably be fine.
hectre13
Dec 11, 2023 08:14 AM
Genopsyde
Oct 7, 2015 08:35 PM
hectre13
Aug 26, 2015 08:17 AM
89fast5oh
Aug 24, 2015 08:14 AM
