TH-350 Does it have overdrive??
Car: 1992 Camaro
Engine: 350 miniram
This car I am looking at has a ZZ4 backed by a TH-350 w/2800 stall and a 3.73 rear. I was wondering if this trans has an overdrive? Does anybody know what the gear ratio's are for this trans? Givin that combo above, will this be ok for a car driven on the street?
Car: 4
Engine: 6
Transmission: 5
People have been driving cars like that for years... I've had a few (late 70s Z28s for example) that came exactly like that from the factory, 350/350/3.73, except of course not with the stall converter....
ICON Motorsports
ICON Motorsports
Car: 1992 Camaro
Engine: 350 miniram
ok well thats good to hear.
So is a 2800 stall to much for the street? And the guy says it is a true 2800 stall, what does he mean by that?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
It means theroretically if you had a transbrake, you could lock the tranny and go to WOT and the engine wouldn't climb higher than 2800 rpm.
Stall speed that's advertised on a converter is only an estimated number. True stall speed varies from car to car depending on how much torque the engine puts out. That converter may stall at 2800 on an engine that puts out 400 pounds of torque but only stall at 2200 on an engine with 300 pounds of torque.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.89
Best MPH on a time slip: 121.52 altitude corrected to 125.89
Altitude corrected rear wheel HP: 497.9
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.546
84 TA NV
Sep 6, 2015 08:02 PM
1987, 350, 350th, 3rd, camaro, dose, engine, fbody, gear, geneartaion, overdrive, th350, trans, transmission, turbohydromatic
