Just put a Torque Converter in =( HELP!!!!!
Old Jul 22, 2001 | 10:41 AM
JucinGTA's Avatar
Well I got a used T/C, that had under 5 miles on it, he said he drained it all the way, I put it in, started the car, and put 7 quarts in, and you put it in gear and nothing happens, I tried every gear and nothin. I also tried reving it in gear and still nothin!!!!I did not drain all the oil, the only oil that was drained was the from when the Driveshaft came out and the converter. What could this be? yes I did click it in 3 times, and I checked the oil level its fine!!!
Old Jul 22, 2001 | 10:44 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Did you install the flexplate to TC bolts?
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
[This message has been edited by GMTech (edited July 22, 2001).]
Old Jul 22, 2001 | 11:57 AM
JucinGTA's Avatar
Of course
Old Jul 22, 2001 | 12:41 PM
JucinGTA's Avatar
The t/c spins and everything!!!!!
Old Jul 22, 2001 | 12:43 PM
sleeper's Avatar
By "clicking" does this mean you shifted the transmission lever on the tranny?
Maybe the shifter cable got broken in the transplant.
Old Jul 22, 2001 | 12:44 PM
JucinGTA's Avatar
I checked to see if it was shifting from the bottom and it was!!!!
Old Jul 22, 2001 | 04:47 PM
JucinGTA's Avatar
Well found out that I might have a 27 spline, and I stuck a 30 in there, they said it fits in, but doesnt engage!!!
Old Jul 22, 2001 | 04:58 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
DOH! That might do it.
FREE CARFAX Record Check
<BR>
South East Thirdgen
GM Master Tech
Savannah, GA
'87 Trans Am
22# injectors,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
'97 Bonneville SSE
Old Jul 23, 2001 | 07:30 PM
JucinGTA's Avatar
UPDATE: I thought I would start the car up this morning, in hope that maybe it fixed it self!!When I started it up it mad this loud A$$ squealing noise!!!So I shut if off instantly, What do you think that means?
Oh by the way I had the trans dropped in 35 minutes, thats pretty sad, considering when I first did one it took me a whole day Im odin this way too much!!!!
Old Jul 23, 2001 | 07:44 PM
Pro Built Automatics's Avatar
The 27 spline input is catching the splines to the point it is going to round itself off. Pull it out immediately, check the splines closely, they will be slightly rounded clean off the shaft of any metal filings and install the correct torque converter. The reason it took the fluid is that the pump hub on the TC is the same on each. The squealing noise is from the mismatch of splines.
Hope This Helps!!!
Old Jul 23, 2001 | 07:47 PM
JucinGTA's Avatar
Thank you pro!!!!
1992 Trans Am
May 10, 2023 07:19 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
jklein337
Sep 19, 2018 06:23 PM
69 Six Pack
Oct 5, 2015 07:51 PM
gwade12
Aug 8, 2015 08:17 AM
