4L80e in a thirdgen?
Old Jul 24, 2001 | 12:34 PM
TheWraith's Avatar
Car: 1987 Camaro IROC Z28
Engine: 355
Transmission: 1994 T56
Axle/Gears: BW 3.27 (stock)
difficult swap??? what's different to worry about??
Old Jul 24, 2001 | 02:08 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The computer for one thing, and I hear it's too big for the transmission tunnel.
Old Jul 24, 2001 | 08:18 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
A TH400 is a tight squeeze and a 4L80E is bigger. You could make it fit but it would mean cutting out the tunnel and fabricating a new larger one.
You would need an aftermarket stand-alone computer also to run the tranny. Companies like JET sell them.
From what I've heard, a rebuilt 4L80E (without the computer) is around $3500. I hope the one in my truck doesn't blow up.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.89
Best MPH on a time slip: 121.52 altitude corrected to 125.89
Altitude corrected rear wheel HP: 497.9
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old Jul 24, 2001 | 08:42 PM
TheWraith's Avatar
Engine: 355
well i saw one on i think it was yahoo classifieds in ohio for $500, unused. And I did read on an older post on here that you can get around the computer issues.
But i'm not about to cut up the tunnel, so screw that. I'll just rebuild my 700r4 to be a monster...
Old Jul 24, 2001 | 10:01 PM
AlkyIROC's Avatar
Car: 87 IROC L98
I don't how you can get around the computer. It controls everything about the tranny. Line pressures, shift points everything. It's a fantastic tranny if you want to spend the bucks on it. There's another valve body available that you can get that makes it into a 6 speed. It engages the OD between 1-2 and 2-3 to give the 2 extra gears. You can also buy a plug in shift programmer. 4 positions. Stock, Stage 1, Stage 2 and Race. It electronically holds the line pressures higher for more firmer shifts just like a shift kit would do. Drive to the track in stock. Race in "race" and drive home in stock.
For a street tranny it's good but it's just too big and heavy for a race tranny. I currently have a TH350 in the race car and want to go to a powerglide.
Frozer!!!
Jan 19, 2024 04:55 PM
Terrell351
Jun 13, 2021 01:13 PM
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
fastrs1891
South Central Region
Oct 20, 2015 09:24 AM
