Rearend swap ?
Old Apr 14, 2009 | 05:43 PM
berlin305's Avatar
Car: 1987 Iroc Z 1990 RS 1991 RS
Engine: 454 soon 496
Transmission: Soon T56
Axle/Gears: 308 Posi
Rearend swap ?
i have a 91 formula bird and a 86 camaro. i want to put the posi rearend in the camaro from the 91 formula bird. can i do this. i am going to do a complete rearend swap is there any mods or they will be okay to do this? just wondering my camaro is my car i drive and the firebird is for parts that i have been parting out. also note i wondered are the wheels going to be different. i am a running 295 50 15s on my camaro and my firebird has 16inch uknown the size. wondering if my tires will bolt up to the new rearend if i do the swap or not? are i know the fox bodies are the same but are they the same for the tires. b/c i want to keep my wheels on my rearend on my camaro just swapping out the rearend to posi. any input much appreciated thanks my fellow bird and camaro friends.
Old Apr 14, 2009 | 05:47 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Rearend swap ?
Originally Posted by berlin305
i have a 91 formula bird and a 86 camaro. i want to put the posi rearend in the camaro from the 91 formula bird. can i do this. i am going to do a complete rearend swap is there any mods or they will be okay to do this? also note i wondered are the wheels going to be different.
Yes, the swap is straightforward. Check the following link for more info:
https://www.thirdgen.org/forums/tran...-10-bolts.html
Is the rear end from the 91 disc or drum? Consider e-brake and speedo gears.
Wheels themselves will bolt up, but I'm unsure about the tires sizes.
JamesC
Old Apr 14, 2009 | 06:02 PM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
Re: Rearend swap ?
I AGREE. straight swap. if youar e going to disk breaks be sure to get the proper brake lines.
Old Apr 14, 2009 | 06:09 PM
berlin305's Avatar
Re: Rearend swap ?
well since i have the 91 firebird can i just go ahead and if discs use the brake lines and the e brake from that car? But again i will have to find out the condition of the lines but if they are good since i have the car would that work?
Old Apr 14, 2009 | 06:46 PM
JamesC's Avatar
Re: Rearend swap ?
If the 91 rear has brake lines, Berlin has what he needs, disc or drum.
JamesC
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
86White_T/A305
Aug 17, 2015 12:16 AM
