Rear ends
Old Jul 25, 2001 | 01:24 PM
Z28DJP1987's Avatar
Rear ends
I have a 87 IROC with a 2:73 rear with drum brakes and POssi.The Possi is shot and also the left wheel brg. Now my questions.
1) Rebuild the 2:73 with a possible gear ratio change and still have the drum brakes.
2) Install a 2:77 rear with disc brakes with Possi from a 1989 IROC, which is available.
The rebuild is gone to be expensive and I still don't known if I can get the gear change on the present set-up? Or go with the 89 IROC rear with the disc brakes.
Finding a rear axle used or rebuilt is
next to impossible. Any suggestions?
Old Jul 25, 2001 | 03:37 PM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
<font face="Verdana, Arial" size="2">Originally posted by Z28DJP1987:
</font>
Old Jul 25, 2001 | 03:47 PM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
Man when I hosed my rearend after taking a corner too fast, I just ripped it out. Could have rebuilt the thing, but I thought it would be eaiser to replace instead. Never rebuilt one, and dont think I would want to try. But the install is not exactly a piece of cake. I just loose fitted all the nuts and bolts and it went together pretty well. You better have some buddies that are willing to help you out too, not easy by yourself. And also, dont quote me, but I thought all IROCs came with Disc brakes in the rear, but not sure. At least my 86 came with them. I thought it was part of the IROC options. But to sum up, if you can find a deal on whole rearend, I'd do that.
Old Jul 25, 2001 | 06:43 PM
Z28DJP1987's Avatar
As the orginal owner I can say all IROC's did not come with Disc brakes. And thanks for your input. Any more comments.
Old Jul 26, 2001 | 02:10 PM
Spyder's Avatar
Unless the rear end is actually bent, I would just find some guy that works at a part store that likes doing it. Myself will do rearends for about 20 and hour and it will take 3-4 hours to put in a new set of gears, bearings, and then if you want goto a differnt posi/carrier.
Old Jul 26, 2001 | 02:53 PM
sleeper's Avatar
I would rather have a 2.73 with no posi than a disk setup. The parts for the Borg Warner disk setup are twice the cost of the drums and only a handfull of companies make gears.
Worst thing I ever did was put in the disk setup... it has never worked properly and I replaced every single part.
Old Jul 26, 2001 | 02:56 PM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
The posi rear you buy might not have any better clutches in it than yours. I ripped out the guts of mine myself (EASY) and paid a mechanic that had experience $50 to set the gears (pinion depth and backlash). He also pressed my new bearings on the pinion and new posi carrier. I then put the axles back in and driveshaft.
91 Camaro RS 5.0L Black Convertible 700R4
** Added so far **
*GM Wonderbar,Alston SFC's,spohn LCA's and Panhard rod
*Turbo City Inj Spacer
*Dual Snorkel Air Filter
*March Performance Pulleys
*GM 3.42 Gears with OEM Zexel POSI
*Edelbrock headers
*3" High Flow Cat
*3" Dynomax Exhaust
*Walbro 255 lph Fuel Pump
***Future 330hp Vortec Crate with LT4 hotcam and 454 TBI
Old Jul 26, 2001 | 04:32 PM
Z28DJP1987's Avatar
Well I made decision today to go with 2:77
9-bolt and the disc's. Its a throw of the dice either way.
1987 Black Camaro IROC-Z (original owner) Replaced LB9 @ 86100 miles.
New 350 Crate engine
Balanced & blueprinted
WP 67cc Heads 9.6:1 C.R.
Cam: 450lift,216dur@50,110ls
TPI Induction(from 305)
22# Fuel Injectors
SLP Intake runners
New Computer chip
K&N filters & Air Foil ,
Hothkis STB
SLP 1 3/4 Headers
CATCO 3" Catalytic conv.
SLP 3" Cat Back Exhaust
700R4 Auto
SLP Torque Converter (2400 stall)
Limited Slip rear
245/45/ZR-17 Tires
17x8.5 ATI 5 Razze Wheels
EST. 340HP
380#/ft of Torque
NEW TOY!
hectre13
Dec 11, 2023 08:14 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
