Motor Mounts Different L/R?
Old Jul 23, 2001 | 12:21 AM
Changa2's Avatar
I popped the motor mounts off an L69 without paying attention to which side they came from. Now I'm looking at them sitting on the bench and they look slightly different and have different numbers stamped on rhem.
One is stamped 3349 71 and the other is 0394 36. Are the Right side and Left side different?
Old Jul 23, 2001 | 10:44 PM
Changa2's Avatar
I read my own post and couldn't quite figure out why there were no responses and all of a sudden I had to laugh, as it reminded me of my own grandson who still has trouble getting his shoes on the right feet. (Chip of the old block? -- pun......).
I could have made my intentions more clear. I don't give a rats a** about the L69 as that was an LG4 transplant anyway but I don't think there is any reason why I shouldn't be able to use those mounts (as fastened to the block) on my #010 block (383) and drop it into an 87 Camaro, as long as I can get them on the right side, if there is a right side/wrong side.
That's my question(s) -- are drivers side and pass. side (block shells) different and if so which is which? ------- I can't seem to get a straight answer from my grandson.......It must be getting late!
Old Jul 24, 2001 | 01:02 PM
ATOMonkey's Avatar
I think that they are identical, but there is a rightside-up and upside-down to them. When I installed my engine I had one of them on wrong and the engine mounts wouldn't seat on the frame mounts right. I'll look at my car tonight and give you a better answer. The steel bars in the rubber are higher on one side than the other.
Sorry wrong engine mounts.
'89 Red Formula 350- 350 .060 over forged pistons 232* @ .020 cam Performer RPM Holley 750 DP Vortec 1.94 1.50 Accel Coil and dist. Hedman shorty headers Dual Exhaust w/ cutouts 1LE WS6 suspension, wheels, and brakes, 9 Bolt 3.27 Posi Edelbrock LCA's & Track bar subframe connectors 700R4 Harwood snorkel scoop Eclipse Head Unit Delco Bose Speakers 2 12" Pioneer subs w/ 400 watt/chanel amp
[This message has been edited by ATOMonkey (edited July 24, 2001).]
Old Jul 24, 2001 | 06:37 PM
b92z28's Avatar
the shells that mount to the engine are the same. can go on either side. the mounts that mount to the frame are also the same. can go on either side. and if i remember correctly you cant mount them upside down.
Old Jul 26, 2001 | 09:40 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
My V6 mounts were identical. Yours should be too.
-Dan
-1990 3.1L RS
-Mods? no
-Slow? yes
Old Jul 29, 2001 | 05:34 AM
PROCHARGED89Z's Avatar
The brackets that mount to the engine cannot be switched.One side lets the motor twist
Check out my Hompage,or the beginnings of one.355 dynoed at 400HP at 5800RPM & 410LBFT of TQ,on Motorhttp://www.procharged89z.cz28.com/index.html
Old Jul 29, 2001 | 10:35 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
They are different. If you look at them you will notice that one has a captive nut, and one doesn't. The one with the captive nut goes on the pass side. The factory did it this way so they wouldn't have to fight with the fuel pump to get a toll down there to the nut. The left through-bolt goes in from the front, at least from the factory.
The L69 was a whole lot better of a motor than the LG4, even though the block and heads are the same. People with LG4s could do well to look at the L69 and understand what makes the LG4 such a POS. You can sort of make your own L69 out of LG4 parts by putting flat-top pistons in it, decent exhaust, a decent cam, the dual-snorkel cold-air intake, and an electric fan. The factory picked up 45 HP in 83 by doing those things.
A garden-variety 350 block like the 010 is absolutely identical on the outside to a 305. Any external things like motor mounts will intercange perfectly. You did the right thing by just snagging a pair off of a car.
ICON Motorsports
Old Jul 29, 2001 | 09:00 PM
Changa2's Avatar
RB,my 383 project pretty much has me on overload but I've been thinking of making that L69 laying in the backyard a winter project. Your comment LG4 vs. L69 makes me think just a bit more of trying to make something out of it.
Back to motor mounts. You talk about a captive nut. I presume you mean a nut that is an integral part of the mount, as in welded on.
Neither mount has such a nut and both of the long bolts and nuts are identical.
I guess maybe it's not that big a thing as I've got a 50-50 chance of getting it right and if not, it should be easy enough to switch. Getting it right on the stand just eliminates one more concern at drop-in time.
I guess I'll get a body sock for that L69 and keep the rain out. Thanks.
E Rod
Aug 28, 2015 05:17 AM
Wesly_66
Aug 26, 2015 09:55 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
