Need help, grinding noise from under console
Old Jul 30, 2001 | 08:45 AM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
After installing an 3000 stall Art Carr TC, my car ran very well and quit. However, after taking it easy on the TC for several days, I proceeded to see how the car would launch at the dragstrip. I power braked the engine up to 2100 rpm and took off. I got plenty of rubber, but the rear end went into wheel hop.
Ever since that wheel hop incident, there is a grinding noise coming from under the front part of the console. At times it sounds like a slinky (if you know what a slinky is).
I have been under the car several times, and can not located the source of the noise. I am so fustrated with my car, I just want to shoot it!!!!!
Does anybody have an idea what it could be?
I'm ready to re-install the stock TC to see if there is a problem inside the Art Carr TC.
'87 L98 TPI IROCZ, AFR190 heads, 3.70 gears, ZZ9 cam, 2400 Art Carr TC, SLP 1 3/4" headers, SLP cat-back, no cat, no AC, no MAF screens, Accel manifold base & SuperRam, 24#/hr SVO injectors, Edelbrock double roller timing chain, MSD ext coil & distributor, trans cooler, 52mm TB with airfoil, TB coolant bypass, AFPR(58psi), K&N filters, Hotchkis lowering springs, my custom chip, Lay Ind. ram air kit, SS Brakes 1LE upgrade 12" rotors dual piston calipers, 265/45R16 Kumho V700 tires.
ET 13.39sec @ 107.21mph
'90 Eagle Talon AWD, no rust thru 9 winters
'99 Camaro SS, red, 6-spd, T-tops, Mcleod clutch, Pro 5.0 shifter, MAF processor, Direct Flow airlid, K&N filter, next mod: 4.10 rear gears
313.7Hp & 320.6ft-lbf, ET 13.55sec @ 105.1mph
Old Jul 30, 2001 | 09:42 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Sounds like your parking brake cable came loose from its brackets and is laying up against the driveshaft...
ICON Motorsports
Old Jul 30, 2001 | 10:07 AM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Well, you might be right.
I only hear this noise when the body is moving on the suspension. On a very smooth road, I do not hear any noise. Also, the e-brake is a little looser because I need to pull on it more to lock the rear discs.
Alright!!!!!!!! This may be it. Thanks.
db057
Jan 10, 2020 08:55 PM
Lbibb
May 5, 2016 12:00 AM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
ndndndnd
Sep 28, 2015 08:00 AM
