frustrated!!
Old Apr 21, 2009 | 05:23 PM
rhill's Avatar
frustrated!!
I have a 1985 camaro z28 with a stock 305 with a 700r4 transmission. when i get to about 35 40mph it wont shift in drive. I dropped the trans pan and changed the filter; no shavings, maybetwo or three very small ones. fluid is nice and red. Tried to adjust the tv cable for pressure still same thing. I bought some of that lucas trans fix and after 2nd time testing it out, it seemed only slightly better; I dont what else to do. Do I need a new trans? Also shifting Hard, After the lucas not so bad..... Need help!!
Old Apr 21, 2009 | 08:59 PM
IROC212's Avatar
Car: 1986 IROC
Engine: 355 Tpi
Axle/Gears: 9 Bolt 3.27
Re: frustrated!!
When it does shift, is it at high RPM's? When you dropped the pan, did you find small pieces of plastic? If so the governor gear may have come apart, or sheared off. There is a round cover on the left (driver) side of the trans. Pry it off and pull out the governor, look at the gear. They're cheap.
Old Apr 22, 2009 | 12:45 PM
rhill's Avatar
Re: frustrated!!
already looked at the gov gear its good. what else could it be? I saw no plastic or anything in the pan...
gta892000
Aug 11, 2019 11:16 AM
1992CamaroGirl
Dec 25, 2017 08:45 PM
RedLeader289
Sep 23, 2015 06:50 AM
Hawkeye1980
Aug 31, 2015 07:09 AM
