Differential whine, leaky driveshaft, bad pinion bearing?
Old Apr 22, 2009 | 10:22 AM
plasmeh's Avatar
Car: 1986 IROC-Z
Engine: 360cu @ 10.5:1
Transmission: T56 - Pro 5.0
Axle/Gears: 4.10 - Zexel Torsen - Moser Axles
About a month ago I swapped in a 3.73 posi rear and noticed when I took it for a spin that at higher speeds when on the throttle, the differential seemed to whine. If I let off the throttle, the whine went away. Crap.
Replaced my old steel driveshaft with an aluminum one the other day and noticed that there is gear oil leaking from where the driveshaft meets the rear differential. I looked up some info on the subject, and I'm thinking a bad pinion bearing? I hear a leaky pinion seal is a tell-tale sign of a worn pinion bearing. Any help is appreciated. Any info on the steps involved in fixing this would also help. Thanks.
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
xxx3man`
Sep 23, 2015 10:37 PM
greenyone
Sep 2, 2015 03:39 PM
RyanJB
Sep 2, 2015 01:27 PM
89fast5oh
Aug 24, 2015 08:14 AM
