gear swap 2.77 to 3.42 is it hard
ok i am gonna trade in my 2.77 with disks brakes for 3.42 drum off a v6 camaro will it be hard to put my disk brakes on instead of the drums that come on the 3.42 how hard of a job will it be .
Dude ,
It will be hell ! If you swap disc to disc,no prob but drum to disc ..... I donk know if you can buy a kit for that. I think you can but for the money you should be able to buy a used one with disc on it at a junk yard real cheep. You can also buy a ring and pinion for about $300 with the install kit. It should be alot easyer that way.
Car: 1986 Firebird
Engine: 2.8 V6
Agreed; I spent over $600 putting a 3.73/posi/disc axle under my car. For $600, I could've gotten 3.73 gears installed to my old 3.42/open/drum axle...
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
could i just use the ring and pinion out of it then . the only prob is i think my clutches are gone in my rear end. but i was told you can take the drums out and slide my disc brakes right in
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Uhm.... no you cant use a 10-bolt gear and carrier into a 9-bolt rear end. They are incompatible.
Search for topics by 88 427 Camaro, he is getting parts for 9-bolts really soon.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.23 @ 107.62 MPH
Southern California
ambainb
Apr 25, 2016 09:21 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
