swapping tranny need help asap
Old Apr 23, 2009 | 02:44 PM
83transAMERICA's Avatar
2nd gear is going out and 3rd is gone. just got a 40K mile 700r4.. already swapped new seals and filter. have the driveline out, the only issue is the drivline brace. we cant undo the nuts on the rear end by the diff. there are no bolt heads just a rubber piece so the bolt and nut just spin together. have any of you encountered such problem?
Old Apr 26, 2009 | 12:45 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: swapping tranny need help asap
You don't need to undo the torque arm from the rear axle to remove the transmission. You can undo the front end instead. After you've done it a few times, it's actually easier.
camaro11j
Sep 19, 2018 08:49 AM
gta90
Sep 15, 2015 04:00 PM
spaigo
Aug 21, 2015 07:46 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
