problems with my LSD
Old Apr 23, 2009 | 05:49 PM
jak2908's Avatar
Car: 89 RS,89 iroc
Engine: 5.0,5.0tpi
Transmission: 700R4,700R4
Axle/Gears: LSD,LSD
i have an iroc limited slip rear end in my car and i have problems with it not locking up around corners...when i hammer it around a left turn most times it kicks all the power to the left wheel..i can get a slide once in a while...and when i hammer it around a right turn there is absolutely no chance for a slide...but has no problem leaving to blackies when power braking it...whats going on? can i rebuild it?
Old Apr 23, 2009 | 05:59 PM
CBR1000RR's Avatar
Car: 91 Z28
Engine: 355
Transmission: 5 speed
Axle/Gears: 10 bolt 3.73's
Re: problems with my LSD
The clutches in the diff. are worn out. It is rebuildable if you can find parts for it. Mine was the same way so I replaced it with a eaton diff. and changed the gears.
Old Apr 23, 2009 | 08:05 PM
jak2908's Avatar
Car: 89 RS,89 iroc
Engine: 5.0,5.0tpi
Axle/Gears: LSD,LSD
if i was to buy a used diff..what would be a good one to buy?..what should i look for?
Old Apr 23, 2009 | 09:23 PM
big gear head's Avatar
You need to find out which rear end you have first. If you have the Borg Warner 9 bolt then you can repairn the differential that is in it.
If you have the GM 10 bolt then you will have the Auburn differential, which is junk. Any used differetnial that you find for this rear end is going to be another Auburn, which isn't worth the shipping cost. The best thing to do is get a new Eaton Posi. It is rebuildable and much better than the Auburn. You will also need to know what the gear ratio is so that you get the right series differential to match the gears.
Old Apr 23, 2009 | 09:38 PM
jak2908's Avatar
Car: 89 RS,89 iroc
Engine: 5.0,5.0tpi
Axle/Gears: LSD,LSD
ya i have the ten bolt...with the 2 series cause i have 2.73's in it...and i want a little more pep out of it..and its not gonna be driven everyday...auto trans also
Old Apr 24, 2009 | 10:29 AM
CBR1000RR's Avatar
Car: 91 Z28
Engine: 355
If you are going to change gears you can get a 2 or 3 series carrier and just get gears to match. Also you can probably get a complete 4th gen rear axle for the same price as just a new diff. 3.23's, 3.42's and 3.73's are all good gears for a daily driver. With tpi 3.42's are what I would recommend.
Old Apr 24, 2009 | 11:09 AM
jak2908's Avatar
Car: 89 RS,89 iroc
Engine: 5.0,5.0tpi
Axle/Gears: LSD,LSD
ya im talkin about the rear end in my RS...its just a 305 tbi now but will be different soon
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
