Whats wrong with my torque converter? (lockup)
Old Aug 4, 2001 | 05:37 PM
kream-'s Avatar
I Finally got my speedometer hooked up so now I have a VSS. Anyway, everything works fine and dandy EXCEPT....
when I'm at WOT, after it shifts it locks up the TC and bogs the engine down. why the hell does the tc lock up at wot????
1988 red Iroc-Z, 56k miles, stock tpi, zz4, 2.77 4wd, probuilt stage 3 700r4, 2800 vigilante TC, TES headers,dynomax 3" catback, nitto DR, ported plenum, afpr, free mods.AIM: IrocZzach
13.4 @ 101mph
Old Aug 4, 2001 | 08:36 PM
Jay 727's Avatar
How is the lock up solinoid wired in your peticular application? Stock? Lock up automatically in fourth? third? How is it wired?
Old Aug 5, 2001 | 12:39 AM
kream-'s Avatar
yeah stock... it works fine except it locks up under WOT
it also doesn't UNLOCK from a cruise...
im thinking about just removing the TC connector completely and using ONLY a switch...
Old Aug 5, 2001 | 07:21 AM
Jay 727's Avatar
That would work. If you have it wired stock there may be a wire in the wrong pin of the trans, they came in several different configurations or it may be the manifold vacuum switch that controls the converter,I'm not sure if your '88 would have one, my '84 did.
You may want to contact pro built, my 700 does the same thing as yours because I have a hot wire going into the trans to the fourth gear switch, when it hits fourth it locks up and stays locked until it down shifts out and into third, I also have it on a switch to turn it off, I usually drive with it off.
Old Aug 6, 2001 | 01:21 AM
Omar's Avatar
Kream, how's it going? How is your Stage 3 holding up?
1989 IROC-Z 5.7L
NOS 5151 150HP kit
ProBuilt 700R4, PI Vigilante 2800 stall lockup
Baer Brakes 12" Sport System
Old Aug 6, 2001 | 02:13 PM
kream-'s Avatar
well besides this lockup problem, everything else is going great...
Dyno Don
Jan 24, 2016 08:24 AM
TheTraut88
Sep 11, 2015 05:16 AM
angel2794
Sep 8, 2015 06:22 PM
TheTraut88
Sep 7, 2015 05:22 PM
andy74
Sep 3, 2015 08:41 AM
