Tranny Swap
Old Aug 6, 2001 | 10:44 PM
Little E's Avatar
Tranny Swap
I just did the tranny swap auto to 5spd. I started it up in neutral and won't go in gear. The clutch pedal goes to the floor with no pressure. The slave cylinder moves about a inch. Did i mess up installing the throw out bearing or is there something else i messed up.
Old Aug 7, 2001 | 03:44 PM
clemsparks's Avatar
Car: 1983 Z28
Transmission: WCT5
From what I'm reading it sounds like there's a missing link in the mechanical part of the equation. It sounds like you're on the right track about messing up the installation concerning the throwout bearing. If it visually looks like the hydraulic setup is functioning properly (like you've described) I'd say you've got a mechanical problem. Try looking at the throwout bearing while somebody pushes on the clutch pedal. go from there.
hope that helps
Clem
SCCA TransAm Series Race Mechanic/CrewChief
1983 Z28 with LG4, 5 speed, and (unfortunately) T-tops
1983 Z28, NO T-tops, (unfortunately) Auto Transmission (hopefully not for long)
camaro11j
Sep 19, 2018 08:49 AM
gta90
Sep 15, 2015 04:00 PM
spaigo
Aug 21, 2015 07:46 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
