Slave cylinder?
Old Aug 8, 2001 | 03:34 PM
Little E's Avatar
Slave cylinder?
Do you guys bleed the slave cylinder why it is attached to the bell housing or do you pull it off like the manual tells you to.
Old Aug 8, 2001 | 03:42 PM
87RS402's Avatar
If it's already on it can't hurt to try bleeding it without removing it. Off is the best way to get all of the air out. If you do try to leave it on the car jack up the frontend as high as you can to move the trapped air closer to the bleeder screw.
FormulasOnly
Jul 23, 2018 08:47 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
meeklay812
Oct 1, 2015 03:46 PM
usafirebird
Sep 29, 2015 11:58 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
