89 RS rear axle play
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
In and out is normal. That's the space between the end of the axle and the cross pin in the differencial carrier. If it's excessive then the c-clip falls out and the axle comes out.
Forward and backward or up and down is either a worn axle or worn axle bearings. If the axle seal isn't leaking then it's probably within tolerances.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.89
Best MPH on a time slip: 121.52 altitude corrected to 125.89
Altitude corrected rear wheel HP: 497.9
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.546
ambainb
Apr 25, 2016 09:21 PM
