lowering problems, tire wear
Old Aug 5, 2001 | 06:11 PM
camaro6spd's Avatar
After a real close inspection of my front tires they seem to be wearing on the outside more the the inside??? shouldn;t it be the opposite witha lowered car? anyway...this means I am not getting full use of the tire area on the front, is there a way to cure this, I not sure how it was lowered, looks like just springs. I bought it this way and the passenger side ground effect is ~ 7 inches of the ground just in front of the Z, in IROC-Z. Could some one measure their 1987 IROC-Z with a 305 and 5 speed. I would like the know how lowered this car is. If I put in IROC spring back in the front and installed lowering spindals would that solve the problem? I love the look but I don't want to loose performance.
Old Aug 5, 2001 | 07:37 PM
camaro6spd's Avatar
CRAP, wrong board, moving it to the suspention board.....
Old Aug 6, 2001 | 01:14 AM
Omar's Avatar
When is the last time you had an alignment?
1989 IROC-Z 5.7L
NOS 5151 150HP kit
ProBuilt 700R4, PI Vigilante 2800 stall lockup
Baer Brakes 12" Sport System
Old Aug 6, 2001 | 04:54 PM
camaro6spd's Avatar
nada a clue, just bought the car and it has a completly blown 305, I just go the new 305 in the motor mounts, and someone on the suspen board told me he had the same problem and that I should check/ buy a new idler arm and get the front end alined. thanks
Old Aug 8, 2001 | 09:15 AM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
If you drive it hard, the outside of the tires wear rather quickly.
Old Aug 9, 2001 | 11:29 PM
kingtaling's Avatar
that would be me.
colton_carlson
Mar 8, 2019 12:21 PM
Infested
May 22, 2018 11:56 PM
demontransam89
Wheels and Tires
Dec 28, 2015 06:58 AM
LT1Formula
Nov 16, 2015 01:13 PM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
