what kind of set up is this?
Old Apr 28, 2009 | 09:04 PM
cmrors90's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI
Transmission: Stock
Axle/Gears: Stock
It is a 9 bolt and it has some tags that come with it barg warner? (P/N10054239 RATIO 3.27 SER.N0-29926) and (SPIN RESISTANT DIFF)
It also come with disc brakes
some guy said that it came of an 88 iroc
feedback appreciated.thanx
Old Apr 28, 2009 | 09:12 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: what kind of set up is this?
sounds like a 9 bolt rear with limited slip and disc brakes and 3:27 gears
what else are you looking for?
Old Apr 28, 2009 | 09:20 PM
cmrors90's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI
Transmission: Stock
Axle/Gears: Stock
could i swap it for the one that my rs has my camaro has 10 bolt with drum which one is better? or could i just take off the rear disc and put them on mine im new at this thanx for the help.
Old Apr 28, 2009 | 09:24 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Yes, you can swap, but you'll need another proportioning valve and e-brake cables.
The nine-bolt is a bit stronger.
You can't swap the disc onto your rear without flange modification or conversion brackets.
For more info on 10-bolts and rear swaps, check the following FAQ:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Apr 28, 2009 | 09:34 PM
cmrors90's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI
Transmission: Stock
Axle/Gears: Stock
some guy is selling it to me for 150 is that a good price it comes with everything it supposed to be from a 88 iroc
Old Apr 28, 2009 | 09:39 PM
JamesC's Avatar
Are the calipers in working order? Does the limited slip function as it should?
Any seals leaking? Are you getting the proportioning valve and e-brake cables?
JamesC
Old Apr 28, 2009 | 09:45 PM
cmrors90's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI
Transmission: Stock
Axle/Gears: Stock
everything is there both ebrakes calipers look good sorry if i sound ignorant but where is the proportioning valve? and is limited slip the same as posi? and nothing is leaking. how do u post pics i have them in my desktop but i dont know how to transfer them. i will do my homework and look at the FAQ you gave me. thanx for this help.
Old Apr 28, 2009 | 09:56 PM
big gear head's Avatar
Posi is Eaton's trade name for their limited slip differential. Posi is used as a generic name for all LSDs. Yes, they are the same.
The Borg Warner LSD is a cone type. When it wears out it will act like a standard differential instead of a LSD (posi). It can be reconditioned, but this requires removing it from the rear end and doing some machine work to fix it.
Old Apr 28, 2009 | 10:04 PM
cmrors90's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI
Transmission: Stock
Axle/Gears: Stock
by doing a visual inspection how will i know if the reconditioning is must before installing it since it is out right now in the garage?
Old Apr 29, 2009 | 06:44 AM
Hold one axles and try to turn the other. If it turns easily then plan on a rebuild. If it doesn't turn easily then it will be all right for a while. Just don't do a lot of burnouts with it while holding the brake. This can cause excess wear on the cones and case.
Old Apr 29, 2009 | 05:43 PM
cmrors90's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI
Transmission: Stock
Axle/Gears: Stock
this is what i gothttp://s649.photobucket.com/albums/u...t=P4281467.jpg
Old Apr 29, 2009 | 05:55 PM
JamesC's Avatar
Open. Oops! Too much Shiner Bock (Black Label) .
JamesC
Old Apr 29, 2009 | 06:17 PM
Looks just like the B-W LSD that was in my 3.27 9 bolt.
Old Apr 29, 2009 | 06:22 PM
cmrors90's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI
Transmission: Stock
Axle/Gears: Stock
the tags are stamped 3.27. I did the Physical inspection and it was pretty hard to hold one axle and see if the other one spin but it did spin but it was hard. Should I rebuild or buy new gears before installing while the rear end is in the garage? what are my options here.Thanx
Old Apr 29, 2009 | 08:26 PM
About the only way to know what condition it is in is to disassemble it and inspect it. You can check the cones to see how far they are from bottoming out in the holes. Getting it back together is a little more difficult than most LSDs. Be sure to mark the case halves so that you get them back together in the same way that they came apart. You must use both axles to line up the splines in the axle gears and cones. If not then you won't be able to get the axles back in when you get the rear end back together.
I think I'd run it and see how it does.
Old Apr 29, 2009 | 08:36 PM
cmrors90's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI
Transmission: Stock
Axle/Gears: Stock
already ill do that i will disassemble and check it out i think im going to install the rear end see how it does also it is a bit rusty could i sand and repaint? if it does need a rebuild do i have to take the whole rear end out again? the only reason im doing this swap is because i dislike the look of the drums and the one wheel burnout although i tend not to do those to often but i like the idea of 2 wheels burning out thanx a mil big gear head.
Old Apr 29, 2009 | 08:54 PM
You can remove the differential without removing the rear end. You will have to remove the brakes and axles to get it out.
Old May 1, 2009 | 07:05 PM
cmrors90's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI
Transmission: Stock
Axle/Gears: Stock
im a bit confused will i have to get a proportioning valve from an 88 iroc or could i use my own?thanx
Old May 1, 2009 | 09:09 PM
JamesC's Avatar
If you change to discs, you can use your master, but you'll need to swap in a proportioning valve. An 88 disc valve would be fine.
JamesC
NORTz89
May 20, 2020 03:51 PM
lt1z350
Sep 29, 2015 01:50 PM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Aug 24, 2015 06:52 AM
mustangdmurder
Aug 21, 2015 07:17 PM
novaderrik
Aug 10, 2015 12:44 PM
