broken speedo cable threads
Old Aug 11, 2001 | 01:16 AM
83CrossfireBomb's Avatar
i just did an engine swap into my 83 Z28 and when i went to put the speedo cable back on the part that it attaches to, the threads, broke off. do i need a whole new tailshaft or can i get new threads or whatever that part is called?
former 305 crossfire fuel injection
350 cubes
hooker headers
750 vac secondary
700r4 with shift kit
Old Aug 11, 2001 | 12:41 PM
kjgroen's Avatar
Car: Trans Am
Engine: L69
what part broke the cable itself or the part on the trans tailsaft? I had the same thing happen the me on the tailshaft.. the housing was plastic and i overtightend it.. you can just get the new speedo housing that goes in the tailshaft at a dealer take your old one out and show them what you need, this always helps the confusion part of it, they only cost about 10 to 20 dollars... Kevin
Old Aug 11, 2001 | 01:40 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
New housings are aluminum too, so that's not likely to happen again.
Old Aug 11, 2001 | 09:35 PM
rock and roll i thought id be searching for a new tailshaft. one more thing though, do i need to totally remove the tailshaft or am i gonna get off easy by just being able to pull that speedo housing off alone and not droping the drive shaft and messing with that traction bar deal that runs from the tailshaft to the pumpkin?
thanks
350 cubes
hooker headers
750 vac secondary
Old Aug 12, 2001 | 02:29 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
All you should need is a 10mm wrench and pliers.
Old Aug 12, 2001 | 11:18 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The little thing that the cable goes to is available at the dealer. New ones are steel instead of the chinesium the OE ones are. Of course they probably cost more than used ones... but the difference in quality will astonish you.
ICON Motorsports
GTAman
Jul 3, 2024 07:29 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
TheTraut88
Sep 11, 2015 05:16 AM
TheTraut88
Sep 7, 2015 05:22 PM
andy74
Sep 3, 2015 08:41 AM
