T-56 stuck in 1st!!!
Old Aug 12, 2001 | 11:37 PM
Chris Etemadi's Avatar
Car: 1991 Z28
Engine: 5.3 Gen III SBC
Transmission: 4L80E NTC 258mm Stall
Axle/Gears: Trick Chassis 9" 3.50 S-Strac
ok on saturday night I was driving around and was persuaded to do a burnout. I did it and I couldnt get out of 1st. It will move down alittle enough to get in neutral but not enough to move over or go in 2nd I tryed my hardest to pull it out with the car on car off clutch in. clutch out. but nothing what could be the problem???
please help. I have to sell this tranny so I need this fixed.(Im going back to auto)
91 Z28 5.7l Camaro
T-56,McLeod Street Clutch, Cross Drilled Brakes, KYB's,AFPR, 3.73 Gears, Borla Adjustable Cat Back, Hypertech Chip, Hooker Headers.
more to come....
My 91 Z28
Old Aug 13, 2001 | 12:05 PM
mrls199's Avatar
Mine did something similar to this, see if you can get it into 3rd, 5th, and reverse... just sit in your driveway and move the shifter back and forth a bunch of times and that should do it. If not, unbolt the shifter from the trans (is it aftermarket? That was the problem i had with mine) and reinstall the shifter (if that does not fix it) and then it should be ready to go
Old Aug 13, 2001 | 10:18 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
I have a 6 speed in my 94 camaro and it has never done this. I don't really have any suggestions but if you get it fixed I might be interested in buying it if you are willing to ship.
Old Aug 14, 2001 | 01:42 AM
Car: 1991 Z28
I have already found buyer.
But thanks for the help
91 Z28 5.7l Camaro
more to come....
My 91 Z28
Old Aug 14, 2001 | 01:58 AM
Car: 1991 Z28
[This message has been edited by Chris Etemadi (edited August 14, 2001).]
tmellott89
Oct 14, 2015 02:06 PM
tonys91rs
Oct 10, 2015 03:31 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
scottmoyer
Sep 7, 2015 07:06 PM
