Pro-Built - Question about TransGo kits....
Old Aug 15, 2001 | 08:13 PM
TheWraith's Avatar
Car: 1987 Camaro IROC Z28
Engine: 355
Transmission: 1994 T56
Axle/Gears: BW 3.27 (stock)
What differences are there between the Correction Kit and the Reprogram Kit? I know the Performance kit includes a video, a servo, and boost valves, but is there anything else? What does the reprogram kit have to allow full manual that the correction kit doesn't have?
Thanks a million in advance....you've been more than helpful on answering all my moronic questions on this board....i definietly owe you a few beers
IROC + Paxton = fast
GT + Eaton = GTP = fast
[This message has been edited by TheWraith (edited August 15, 2001).]
Old Aug 15, 2001 | 09:33 PM
TheWraith's Avatar
Engine: 355
Old Aug 15, 2001 | 09:57 PM
TheWraith's Avatar
Engine: 355
btw, before i get throttled for not searching past posts, i did, and i didn't find everything i need to know, such as what constitutes the manual valve body setup.
Old Aug 15, 2001 | 11:08 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
From a quick look at my instructions for the 700-2&3 it looks like the full manual installation involves plugging 2 holes and drilling 2 extra holes in the VB, and installing the governor spring in a different way.
Old Aug 16, 2001 | 08:33 AM
TheWraith's Avatar
Engine: 355
<font face="Verdana, Arial" size="2">Originally posted by Apeiron:
From a quick look at my instructions for the 700-2&3 it looks like the full manual installation involves plugging 2 holes and drilling 2 extra holes in the VB, and installing the governor spring in a different way.</font>
so you can actually do the full manual setup with the 700-2&3 / NoYoYo kit??? I didn't know that.
Old Aug 16, 2001 | 02:39 PM
Pro Built Automatics's Avatar
The Trans-Go Performance Shift gives you a new 3-2 valve (1) allows faster 3-2 downshifts by allowing oil to exhaust from the 3rd clutch pack quicker (2) eliminates most of the 2-3 & 3-2 tieup (prevalent in stock applications) (3) has further modifications done to the valve body plate to give the ability to hold any gear to any rpm (4)new TV system that will not stick, etc. I do not recommend the manual setup, to many problems can occur. All my builds are full automatic, you stiil have the ability to hold any gear as stated sbove. There are two different kits available one with video (Summit) and the one that I carry without video. Mine has the Corvette servo with Viton sealing rings, both boost valves, and Performance Shift kit. It sells for $125.00. If I can be of help let me know.
masonta
Sep 1, 2015 06:40 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
crazynights
Aug 21, 2015 06:53 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
