How much slack should there be in 9 Bolt gears?
Old Aug 16, 2001 | 06:16 PM
86IROC305's Avatar
I have been noticing this thudd coming from drivetrain somewhere in the rear of my car. It only does it when I first put it in drive or reverse and when it downshifts to first.
I've just about rulled out the U joints and the tranny mount is good, so I checked the rear for play in the gears and I can turn the driveshaft about 1/4 inch or so before the axels turn the wheels. Is that normal ? I'm trying to troubleshoot what else could cause it.... Thanks Joe
86 TPI 305 Iroc-Z
700R4 (rebuilt)
9 Bolt Rear Disc Swap
Accel HEI SuperCoil
Flowmaster
K&N Filters
Comp Cams 260H-12
212/212 444/444 @112lsa
Old Aug 17, 2001 | 07:42 PM
86IROC305's Avatar
Old Aug 17, 2001 | 08:45 PM
ede's Avatar
ede
if you're talking about backlash set up an indicator to measure it. i'd guess it should be around .008, check a manual to be sure.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
hectre13
Dec 11, 2023 08:14 AM
junkcltr
Aug 2, 2019 11:12 PM
hectre13
Aug 26, 2015 08:17 AM
Dialed_In
Aug 20, 2015 01:45 PM
