Info on Trans
Old Aug 15, 2001 | 11:15 AM
Deimos's Avatar
Info on Trans
Sorry, it may sound dumb but I dont know this.Im thinking of doing the 3.8 GN swap on my V6 camaro. and I was wondering if the Buick Transmission is going to hook up nicely under our cars or is there need of cutting or spacing? all the info is appreciated
Old Aug 15, 2001 | 11:42 AM
Deimos's Avatar
I was looking at the Buick and Gm transmissions and was wondering if I could use the 4L60-E transmission in this 86-87 3.8 turbo swap? what transmission did the Turbo T/A have? anyone know this please help guys.
Old Aug 15, 2001 | 01:08 PM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
4L60e are electronic and have to be run by a computer. The 86-87 Grand nationals didn't have computerized trans so that might be a problem. I have a 91 4L60 for a V6 Camaro if your interested in it. Make a good deal on it. Ran good til car was totaled. I bought the car for the wheels and 3:42 rearend. brian@bharris.org
91 Camaro RS 5.0L Black Convertible 700R4
** Added so far **
*GM Wonderbar,Alston SFC's,spohn LCA's and Panhard rod
*Turbo City Inj Spacer
*Dual Snorkel Air Filter
*March Performance Pulleys
*GM 3.42 Gears with OEM Zexel POSI
*Edelbrock headers
*3" High Flow Cat
*3" Dynomax Exhaust
*Walbro 255 lph Fuel Pump
***Future 330hp Vortec Crate with LT4 hotcam and 454 TBI
Old Aug 15, 2001 | 01:43 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I'm pretty sure that the TTA used the 200-4R tranny. I don't know if it was because of size (wouldn't fit the tunnel?) reasons, or if it's because of the smaller difference in ratio between 1st and 2nd gear. The 200-4R might've "outperformed" the 700r4 trans in acceleration tests...??
-Tom P (Hot rodded 1986 Firebird 2.8l)
Old Aug 17, 2001 | 03:54 AM
transfixleo's Avatar
The 200-4R is better suited to keeping the Turbo spinning once it starts.
Old Aug 17, 2001 | 05:53 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Is it a bolt-pattern issue too? Does the 700R4 even fit the Buick V6?
Old Aug 19, 2001 | 01:51 PM
No it does not fit the BPO block but that is not the issue. The 200-4R has a closer gear ratio pattern than the 700 does and it would likely drop the turbo off after the 1-2 shift if you tried to use it.
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Hello, Michael
Aug 20, 2015 03:19 PM
gta power
Aug 13, 2015 06:15 AM
mizz0313
Aug 12, 2015 06:45 AM
Leggman1
Aug 6, 2015 04:15 AM
