Accumulator Piston & Boost Sleeve
Old 08-19-2001, 02:05 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
can any one tell me how to install these in a 700r4 or is there a web site the info?
1991 banditt2 #130 of 600
Project 350 TPI Banditt II
http://www.street-dawg-racing.cityslide.com
http://discussion-board.com/GreaterC...dyAssociation/
http://www.cincyspeed.com/
Old 08-19-2001, 05:42 PM
transfixleo's Avatar
The boost sleave goes into the pump but can be done in the car. The accumulator depends on which one you are talking about. Do you mean the Servo by any chance?
Old 08-19-2001, 10:30 PM
91banditt2's Avatar
Engine: 5.7 HSR
i have the corvette servo,accumulator piston and boost sleeve.i bought a kit form http://www.hptransparts.com/
look under 700R4 servo kits part #HP35952-K.they have a pic there of the kit
Old 08-20-2001, 04:23 AM
OK, the Servo is on the drivers side, held in with a snap ring. It will require unbolting the crossmember and pushing the tranny to the side to get it in and out. That will be the hardest part of the job. Hopefully you don't already have the 'Vette Servo in there! The pan and VB will have to come off for the accumulators. One is in a housing on the passenger side rear and the other is above it and the Separator Plate in the case. The Boost Valve goes in the pump near the filter inlet.
For the work involved I would be putting a TransGo Shift Kit/Reprogramming Kit to really FIX and improve the tranniesperformance and life. JMHO.
Cam-aro
Camaros Wanted
11-12-2015 03:35 PM
LT1Formula
10-08-2015 08:34 PM
loud91rs
10-05-2015 10:05 PM
Dragonsys
09-25-2015 03:51 PM
Quick Reply: Accumulator Piston & Boost Sleeve
