Got a simple question (I hope)
Old Aug 20, 2001 | 07:20 PM
87ROCZ's Avatar
Car: 1987 Camaro IROC-Z
Engine: L98 bored .40 (357 ci)
Transmission: Race Ready 700R4
Axle/Gears: 9 bolt 3.70 posi
I am new to this board and new to the F Body scene so bare with me :-)
I recently bought a 1987 Camaro IROC-Z and first I have to say this car kicks A$$!! Its in great shape and the engine pulls good but I have a nagging quesiton..
In the morning I will start her up and let it warm up. Then when I put it in reverse she hesitates for a second and jerks into gear. The upshifts does the same for the first couple of miles of driving. After the first couple of miles and evrything is warmed up good she shifts smooth and engages into reverse smoothly without the jerky clunk.
I am not sure how the car was treated before me ( I can only imagine the worst as these cars can take the punishment so I am told). But is this something to worry about? Is it a sign of bad things to come or would a little general maintenace and TLC fix this up?
PS: This board ROCs!!
Stan
1987 Camaro Iroc Z
350 TPI..TH700R
Old Aug 20, 2001 | 08:03 PM
ede's Avatar
ede
welcome to thirdgen.org. i'm not expert but i pretend to be on here, first thing i'd check is the fluid level and if it's good change it and the filter.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Aug 20, 2001 | 08:07 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Welcome aboard,
You came to the right place for help,
Definately change the fluid, most people ( that don't care about there cars or don't have the know how) don't change the tranny fluid, they remember oil changes but not the tranny. Invest in a good tranny cooler as well this will add life to the tranny.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
FLOWMASTER, NO CAT
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat
2:73 GEARS
Rebuilt 700R4, with manual valve body
B&M Megashifter, 5" Autometer Tach w/shift lite
Soon to be installed
3:73 Richmond Gears and 3" Hooker Aero Chamber
Corvette Servo & .500 boost valve
15.61@ 95.2mph G-Teched, 1-2 shift slippage, and just replaced a burnt plug wire
"There is nothing more addicting than speed"
87ROCZ's Avatar
Glad ot be on the board... :-)
Well I did check the level and it looks good, hummm I should be checking that when the engine is hot and its in park right?? DOHH!! hehe, I will do that tomorrow morning...the fluid is the proper redish/pink color as well...I may as well do a tranny flush on her I guess. Can't hurt.
Thanks for the reply. If anyone has any other ideas of what it can be let me know
1987 Camaro Iroc Z
350 TPI..TH700R
Old Aug 20, 2001 | 09:05 PM
Car: 99 Formula
Axle/Gears: 342
To get a proper reading, the car has to be running then run through the gears, R P D, then Park and check your level.
Caspar
Jun 19, 2016 11:19 PM
CORV3TT3
Aug 23, 2015 11:26 AM
Fronzizzle
Aug 17, 2015 02:52 PM
redmaroz
Aug 16, 2015 11:40 PM
camaroken83
Aug 10, 2015 11:35 AM
