tranny cooler install ?'s
Old Aug 20, 2001 | 12:59 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
What are the unwritten things to look out for? When you cut the cooling line, how do you keep metal shavings from getting in the fluid? Do you have to drain the tranny before you install the cooler? Anybody who's done this install, can you give me any tips and generally anything to watch out for.
'91 GTA
350 TPI
700R4 from Pro-built
T-Tops.
Just a few mods, if you want to find out just line up next to me at a stoplight!
Wife:2000 Grand Prix GTP
Old Aug 20, 2001 | 04:29 PM
ede's Avatar
ede
use a tubing cutter and the metal chips won't be a problem, mount and run the lines so the fluid is forced to run uphill thru the cooler.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Aug 20, 2001 | 04:31 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
My B&M Supercooler came with fittings; I didn't have to cut any of the metal cooler lines. If you think you get metal filings in the line, you could always unhook it at the trans end, and pour clean trans fluid into the line so it washes any metal filings out.
-Tom P (Hot rodded 1986 Firebird 2.8l)
Old Aug 20, 2001 | 09:22 PM
breathment's Avatar
<font face="Verdana, Arial" size="2">Originally posted by ede:
</font>
why? just curious.
88' GTA 350 MODS---&gt; air foil, K&N, Shift Kit, 180* therm, TB bypass
toronto formula
Nov 10, 2015 06:17 AM
spaigo
Aug 21, 2015 07:46 PM
crazynights
Aug 21, 2015 06:53 AM
TreDeClaw
Aug 14, 2015 06:58 PM
drathaar907
Aug 6, 2015 04:20 PM
