Is a 4L60e better?
Old Aug 23, 2001 | 09:15 AM
GTA600's Avatar
Is a 4L60e better?
I have to rebuild my tranny for the engine Im putting in my car. I was going to rebuild using a Art Carr rebuild kit for up to 750 hp. However Im considering using a 4L60e tranny. What are the benefits of swapping to a 4L60e?
Matt
87 GTA LB9
Spohn LCA's and relocation brackets
WS-6 suspension
Spohn Adj. Panhard
Spohn Adj. Torque arms 1 deg. preload
Spohn Subframe connectors
Edelbrock Strut tower brace
Eibach springs lowered 1"
KYB all 4 corners
Energy suspension bushings in rear and PST front end kit
Currie 9" 3.70 posi rear
automatic
no times yet
Old Aug 23, 2001 | 10:42 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I know one good thing about them that I wish mine has, in Summit they sell a computer type switch that allows you to pick the settings of firmness of the shifts. Much easier than installing a shift kit.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
FLOWMASTER, NO CAT
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat
2:73 GEARS
Rebuilt 700R4, with manual valve body
B&M Megashifter, 5" Autometer Tach w/shift lite
Soon to be installed
3:73 Richmond Gears and 3" Hooker Aero Chamber
Corvette Servo & .500 boost valve
15.61@ 95.2mph G-Teched, 1-2 shift slippage, and just replaced a burnt plug wire
"There is nothing more addicting than speed"
Old Aug 23, 2001 | 07:22 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Absolutely no change. I don't understand why everybody thinks a 4L60-E is stronger. Its not. Its basicly an electronicly shifted 700R-4. Most of the parts in a 4L60-E are the same as the 700's.
FREE CARFAX Record Check
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
Old Aug 23, 2001 | 07:59 PM
93ND500's Avatar
I've got one. Don't know about the benefits....other than no TV cable. But a MAJOR complication is the need of an additional computer just to control it.
Old Aug 24, 2001 | 04:51 PM
transfixleo's Avatar
The only benefit is the Sprag Assy and the 3-4 clutch pack. Other than that you will have to invest in a computer to operate it.
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
Nervous2
Oct 8, 2015 10:53 PM
LSXcamaro
LSX and LTX Parts
Sep 17, 2015 11:17 PM
IROCZ1989
Sep 4, 2015 11:54 AM
f-bodyz28
Sep 2, 2015 05:03 PM
