Do I have a long or short tail TH350?
Old Aug 27, 2001 | 12:43 AM
crazeinc's Avatar
How do I know which one I have? Which one is the stronger one?
1990 GTA
-355 carb'd, nicely reworked '64 vette heads, 2500 stall, 4.10's, other small things.
-Alston SFC's, Eibach Pro-kit, Koni's all around
-100+ nitrous shot
-Cruising in style with leather and nice stereo.
Old Aug 27, 2001 | 08:55 AM
82camaro's Avatar
Car: 82 camaro SC
Neither is really stronger. The longer one is usually more common in pickups. Measure the length of the tailshaft housing. 6 is short 9 is long I think.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
Old Aug 27, 2001 | 04:42 PM
crazeinc's Avatar
which one works with a 200r4 driveshaft in a thirdgen with a 10 bolt?
Old Aug 27, 2001 | 05:06 PM
Cosmik Debris's Avatar
I think the short one. You can either use a short 350 and 200 shaft or a long 350 and the 700R4/T5 shaft.
Old Aug 27, 2001 | 07:18 PM
crazeinc's Avatar
didn't know that, thanks!
Old Aug 28, 2001 | 02:24 PM
spud's Avatar
Car: 82 & 91 Firebird
Engine: 400 & 355
Transmission: TH350 & 700
Axle/Gears: 4:11 & 2.72
Crazy
What ever happened to your 82.
Later
Spud
Old Aug 29, 2001 | 11:48 AM
crazeinc's Avatar
Spud,
The engine, trans, and rearend from the '82 are in the GTA so it still lives on, but the body in the camaro was a mess so I had to cut my losses and move on. Found the GTA as a rolling chassis with leather interior and a nice suspension...I'm very happy
383cam
Sep 9, 2015 06:01 AM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
BOOT77
Sep 5, 2015 03:55 PM
rudolphschenker
Sep 4, 2015 02:41 AM
