9-Bolt whining afer new gearset installed
Old May 16, 2009 | 04:33 PM
Hello, Michael's Avatar
Car: 1987 Pontiac Firebird Trans Am WS6
Engine: SBC 350
Axle/Gears: 3.70:1 BW M78 9-Bolt Posi
I upgraded my 9-bolt from a 2.77 to a 3.70 and I'm getting a whining noise under VERY light throttle, and when coasting. Ran a pattern on the gears and it seemed to be pretty much centered, maybe a little bit towards the toe of the gear, but not by much. New bearings were installed everywhere as well as a 3-series carrier I bought off of ebay. Car seems to be running fine with no clunks or grinding or anything. Any ideas? Perhaps the backlash is a little off? Is this a cause for concern? I talked to a guy who rebuilt a 9-bolt and he said he had trouble with whining too. Said he pulled the thing apart and checked everything, but it still whined.
Old May 16, 2009 | 04:38 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 9-Bolt whining afer new gearset installed
Maybe this is why Randy's offers a 3.73:1 instead?
Old May 16, 2009 | 04:44 PM
Engine: SBC 350
I was told that a 3.73 was not available for the Australian 9-bolt. 3.70 and 3.73 ratios are not that different either.
Old May 16, 2009 | 04:46 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Ah, but they are. A 37-10 r&p has different tooth pitch than 41-11. Let's let BigGearHead weigh in on this.
Old May 16, 2009 | 04:57 PM
Engine: SBC 350
So is it possible that the noise is caused by the gear pitch? I could care less if the diff is noisy. I just want to make sure I'm not imposing any damage on anything.
Old May 16, 2009 | 11:37 PM
big gear head's Avatar
As far as I know all 9 bolt 3.70 gears make the same noise. Some places will tell you this before you place your order. All I can tell you is to get a louder exhaust or better sterio.
Old May 17, 2009 | 09:07 AM
gcpoland's Avatar
Car: 86 MCSS-87 Z28
Transmission: Auto OD-5spd
Axle/Gears: 3.73 both cars
It whines because the gears are to tight. Your shim stack is wrong.
ZMWojnar
Brakes
May 12, 2019 10:43 PM
chazman
Aug 28, 2018 03:25 PM
Infested
May 22, 2018 11:56 PM
chazman
Aug 22, 2015 02:01 PM
knight72
Aug 10, 2015 09:32 PM
