4th gen rear end swap
Car: 85 Trans Am WS6
Engine: 305HO L69
how hard would it be to swap a 4th gen rear end into a 3rd gen? does it matter if the 4th gen rear is from a v6 or a v8? would you have to do anything extra for the swap if you're changing out a drum rear?
youll need the prop valve from 4thgn, gtg.
write more later...
91 FireBird 305 V-8
Edelbrock Catback, Custom Alarm. Fourth Gen Console. i have six cupholders. all for starbucks!
Go|)Created The Earth, And Then Turned Up The Bass.
Here's My Audio Install!
"Honda's FOR ME TO POOP ON!" -Triumph...
write more later...
91 FireBird 305 V-8
"Honda's FOR ME TO POOP ON!" -Triumph... Most 4thgens have ABS and you cant use their prop valve. Just use a prop. valve from a thirdgen that originally came with 4-Wheel discs. A junkyard should have it. Other than that, the 4th gen rear is a direct bolt-in. FWIW, the 4thgen rears are about 3-4" wider, so your tires will stick out a little further than normal. It still looks fine though, IMHO. The edge of the tires will almost be even with the fenderwells.
Try to get the rearend from a V8 car, b/c ALL V8 4thgens were posi.
89' pearl blue Camaro Iroc-Z
355/6-spd
Not stock...
97' black Pontiac Trans Am
LT1, A4, free mods, CAI,
HPP3+, Flowmaster catback, 3.42's.
100hp Nitrous.
355/6-spd
Not stock...
100hp Nitrous.
After the fact
I've got a 98 rear with 3.23 posi, and it does bolt right on. However, I have had problems with my tires rubbing up against the lip of the wheel well. I'm not sure why either, I'm soon to be replacing my suspension with Eibachs, but thought to leave this note. If anyone knows why this is happening, plz let me know, it only happens on bumps and things, it's not like I'm sagging down that far. Thanks for all that post help.
Car: Take
Engine: Your
Transmission: Pick
Re: After the fact
Originally posted by Mike91rs
I've got a 98 rear, I have had problems with my tires rubbing up against the lip of the wheel well. it only happens on bumps and things
Understandable
I know what you mean, I'm just saying I've looked all over and not seen where anyone else is having this problem. I am riding on thicker tires, P235/R6016 which could also be attributing to the problem. Thanks for the post though, and do you think that me upgrading my suspension to the Eibach sportlines is going to be a bad thing?
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Not all 4th gen V8 rear ends are posi.
Depending on the 3rd gen wheels you have, the wheel can stick out too far and look kinda funny.
I can take a pic of my friends 92 Firebird this week and post it.
Get a complete rear out of a V8 6 speed car, you'll get disc brakes, posi, and 3.42 gears.
I've got a 2.73 open rear from a 95 Formula for sale cheap (maybe even free). I just won't ship it.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
AkDrifted
Aug 17, 2015 07:45 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
