Can a TV cable adjustment problem affect your REVERSE gear?
Old Aug 29, 2001 | 07:59 PM
jigga27's Avatar
My friends tranny slips in almost all gears. And when put it in REVERSE and press the accelerator, the engine just revs and the car very slowly backs up (no matter how hard you press the gas). Could this be a TV cable adjustment? Or is this definitely a tranny change?
Ron Strayhorne
91 350 V8 T.A./ MSD ignition box & wires;Flowmaster cat-back exhaust;K&N filter;Crane perf. coil; semi-polished engine;Random Technology cat sitting in the garage til I can afford the other one;Pro-built stage 3 tranny in the mail...cant wait!!!
Best 1/4 mile time: 13.8@ Speedworld Motorplex (used to be called Phoenix Raceway Park). I was so excited I forgot the mph.
http://members.tripod.com/strayhorne/car.htm
Old Aug 29, 2001 | 09:13 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
The tv cable controls line pressure for shift points, I don't believe it has anything to do with reverse, but I could be wrong.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
FLOWMASTER, NO CAT
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat
3:73 Posi
Rebuilt 700R4 vette servo and .500 boost valve
B&M Megashifter, 5" Autometer Tach w/shift lite
Soon to be installed
3" Hooker Aero Chamber
Old Aug 30, 2001 | 04:52 AM
transfixleo's Avatar
The TV Cable has a dual purpose. What it really does is sends throttle position to the VB. That info in turn is used to bothe delay shift points AND raise pressure as more throttle is added.
As to your problem, is there ANY problem in Forward? Try putting it in manual low at @25 MPH while coasting. If it doesn't pull down hard then your Low/Reverse Clutches are going out. If that works fine then your Reverse Inputs clutches are the culprit (they only work in reverse).
Old Aug 30, 2001 | 07:05 AM
jigga27's Avatar
It has this problem in FWD (all gears) too. I will try to adjust the TV cable for him 2nite. But I doubt it will work.
Ron Strayhorne
Frozer!!!
Jan 19, 2024 04:55 PM
mizz0313
Aug 12, 2015 06:45 AM
dhonda200
Aug 11, 2015 11:50 PM
hokis
Aug 9, 2015 03:57 PM
