Electronic Speedo Gears...HELP PLEASE!
Old Jul 16, 2001 | 12:37 PM
BlackBird305's Avatar
ok i recently put in a new carrier and 3.73's...i've got the 700-R4 but i don't have a cable driven speedo...a friend of mine has the same car and tranny and his is...i found out mine is electronic but i need to know the name of the piece that the metal shaft in which the cone gear slides on to is called...its the round plastic piece w/the o-ring in the center...the metal shaft broke on mine so i cant slide the new gear on...is this called the sending unit or something?...i need to know so i can get a new one...thanks a lot guys
BTW...the one i have is a little narrower then the cable drive but it looks the same
Old Aug 31, 2001 | 10:10 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
ttt
Old Aug 31, 2001 | 11:02 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
I beleive that would be your VSS.
FREE CARFAX Record Check
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
InfernalVortex
Apr 20, 2021 11:31 AM
Elephantismo
Feb 13, 2019 12:51 AM
MrPackstin
Oct 25, 2017 08:09 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
anesthes
Sep 30, 2015 07:48 AM
