9" Ford Ring Gear 4:11 Contact Pattern
Old May 19, 2009 | 04:59 PM
RAPIDFIRE's Avatar
Car: camaro z28 84
Engine: chevy 468
Transmission: th400
Axle/Gears: 9 inch 3.25/4.11,axles moser 31 spl
The pictures posted below are with .076" shims. What do you guys think of these patterns,does it look correct? The first picture is the coast side,i'll have to go get another picture of the drive side,it was to big.
The pictures posted below are with .050" shims.
I talked to some people on another forum,and they said .050"-.070 shims sounded like alot for a 9" ford rearend,and most use around .020" of shims.
The pinion on our new richmon gear set,says to set the pinion at a 1.035"
I put a load on the ring gear with a pry bar and turn the pinion by hand.
help help ??????
Old May 19, 2009 | 05:00 PM
RAPIDFIRE's Avatar
Car: camaro z28 84
Engine: chevy 468
Transmission: th400
Re: 9" Ford Ring Gear 4:11 Contact Pattern
Old May 19, 2009 | 05:21 PM
big gear head's Avatar
The pinion gear is too deep. Notice that the contact pattern is concentrated at the root of the tooth. It needs to move up to the center of the tooth, half way between the root and the face. Don't be too worried about the heel to toe position, get the root to face position right.
I see that you are using a Detroit Locker. What other parts are you using in this?
hectre13
Dec 11, 2023 08:14 AM
lt1z350
Sep 29, 2015 01:50 PM
hectre13
Aug 26, 2015 08:17 AM
InfinityShade
Aug 22, 2015 08:00 PM
