No 4th gear...already tried a search.
Old May 21, 2009 | 08:07 PM
PneumaticTire's Avatar
Car: 1986 Camaro Z28
Transmission: Who orders an auto in a Camaro??
Axle/Gears: Economy gears..once again, WHY?!?
I have a 86 IROC I recently aquired. I have changed the filter and fluid, and realised I do not have 3rd gear after taking it out on the highway for the 1st time today. I tried adjusting the TV cable per ALLDATA instructions, but my TV cable never "clicked" when I opened to WOT. Not sure if that is my problem or not. When I dropped the pan, there was NO large chunks of metal on the magnet, fluid looked normal to what I would expect on a car so old. 1-2-3 and OD all work fine. NO slippage noticed under WOT, etc. Ideas please??? I can fix an engine, but when it comes to transmissions, I don't know a whole lot. lol. Thanks guys.
Old May 21, 2009 | 09:19 PM
Re: No 4th gear...already tried a search.
It's been a long day guys, sorry I meant i have no 4th gear while on the highway. at least i think....my rear end is a 3.23 and i went up as high as 90 and it seemed like i was tached out too high, and could feel the resistance in the gears when i let off the gas..this doesnt feel right. remember, it does have OD, never slips, has 1-2-3 that feel all normal.
Old May 22, 2009 | 10:54 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
The method of setting the TV by flooring the go pedal has never worked well for me, I do it underhood, by hand, so that the cable itself is tight with the throttle wide open. Next, your stock trans will not do a full-throttle 3-4 upshift without buying a kit from B&M. If you have your TV set correctly, and the correct amount of fluid, and still have [roblems, start saving your $ for another trans.
Old May 22, 2009 | 08:09 PM
hmmm...so what you are saying is that I may actually have 4th it just doesnt stay in it when i get back on the gas some to try and go faster? I'm wondering if I am just smoking rocks. I adjusted the tv cable under the hood again this morning, this time, it clicked twice when i oped the throttle to stop. I think it's actually ok. I will find out once I figure out what the RPM's actually are in each gear once I get the gauges fixed!! Tach is stuck up high, fuel gague is erratic, as well as oil pressure, and the temp gauge is pegged out beyond max.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
dbrochard
Exterior Parts for Sale
Oct 10, 2015 01:03 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
drumstixer
Sep 29, 2015 03:02 PM
Dragonsys
Sep 25, 2015 03:51 PM
