Unknown axle code ????
Old Sep 3, 2001 | 10:34 AM
Federico's Avatar
my 83 Z28 has 6HS has axle code ,but on the haynes manual is not contemplated, i guess my axle came from another car!
COULD SOMEONE GIVE ME AN ANSWER !!!!!
Old Sep 3, 2001 | 10:42 AM
Federico's Avatar
oh yeah i have a 3 speed trasmission th-200-c i think
Old Sep 3, 2001 | 11:04 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It's pretty much a waste of time to fool around with those codes, especially when stuff has been swapped around; nobody goes and finds the right sticker to stick on there when they do stuff like that. Just open it up and look.
Have you changed the rear end fluid lately? Then you need to pop the cover off anyway.
ICON Motorsports
Old Sep 3, 2001 | 02:40 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
According to my lists, there were no A3 V8 cars in 83. The 200C was only offered in 82 for V8 cars. V6 and I4 cars were still able to have it in 83. There are no V6 Z28 cars.
If the car is actually an 82 then a Z28 4bbl car and an A3 came with 2.73 gears. If it's fuel injected then it had 2.93 gears or if it had the G92 option it came with 3.23 gear.
If the car is a V6 83 then they only had the option of 3.08 gears with an A3
If the diff isn't original then pull the cover, count the teeth and change the gear oil.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.89
Best MPH on a time slip: 121.52 altitude corrected to 125.89
Altitude corrected rear wheel HP: 497.9
Best 60 foot: 1.546
Racing at 3500 feet elevation with a typical race day over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old Sep 3, 2001 | 03:06 PM
Federico's Avatar
i know , it's strange 'cause my my car is an 83 camaro z28 (i've checked the vin code)but i think that the trasmission and the rear axle are from another camaro, or maybe is one of hte first 83 camaro .
If you look on page 188 ( haynes manual),under trasmission type:
1982 200c
1983 200c;700 r-4
1984 700 r-4
WHAT YOU THINK?
6speedIROC
16
Mar 15, 2023 08:33 PM
Numbah-1
Sep 20, 2015 09:31 AM
Liveaction
Sep 17, 2015 06:29 PM
dbrochard
Sep 7, 2015 09:41 AM
rudolphschenker
Sep 4, 2015 02:41 AM
