T5 Weakness
Old Sep 4, 2001 | 11:52 AM
z28dan's Avatar
T5 Weakness
I have heard that T5s weakness is from flexing of the case causing failure. Do you think the torque arm has something to do with this? You have the motor twisting one way and the rearend doing another. Any thoughts?
Old Sep 5, 2001 | 03:35 PM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
My transmission guy says case is a problem, but also size of bearings limits amount of heat that trans can deal with. More torque,
more shaft speed, more heat=fragged T5.
Had him replace 2nd gear, 1 fork, input shaft and bearings/syncros at 60,000 miles.Won't waste any more $ on the T5 though.When it starts going away this time it'll be replaced by a Tremec or Richmond.With a rebuilt T5
going for $1200, it pays to spend a little more and buy a transmission that will hold up, in my opinion.
1992 RS,5 Speed,T-Tops,Eibach Springs(cut), KYB's, Lakewood Trailing Arms and Adjustable Panhard Bar,Posi Disc Rear,3.73 Gears,Summit Rearend Support Cover,
Del-A-Lum Bushings,300 HP Crate Motor,Crane Comp-U-Cam,Edelbrock TBI Intake, Turbo City Ported Throttle Body and Adjustable Fuel Pressure Regulator,Open Element
Air Cleaner, Ground Control Strut Tower Brace and Caster/Camber Adjusters,SLP 1-5/8" Headers,Flowmaster 3" American Thunder Exhaust,3" Cat,Centerforce Dual
Friction Clutch,Hayes Billet Flywheel,B&M Power Steering Cooler,Big Thumpin' Stereo.
Old Sep 5, 2001 | 09:31 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The biggest problem I have seen is that the case is too weak; it stretches acroass the front between the clutch gear and the countergear, which allows the gears to misalign, which makes them wear extremely fast. That's why you had to change your clutch gear and countergear. The synchros almost never wear out; they're a waste of money. Everything about the trans is small; it was never meant to be a high-performance piece, it's engineered for gas mileage.
The torque arm has nothing to do with it at all.
ICON Motorsports
Falcon50
Aug 22, 2020 03:26 PM
Twin_Turbo
Mar 14, 2016 10:10 PM
lanceflame44
Sep 25, 2015 12:28 PM
Racerx974
Sep 19, 2015 10:16 AM
cstrobel65
Sep 16, 2015 11:54 AM
